Congrats, you just bought an excellent display!
Like I said, I ran the slides nonstop for 5 days and I know
many others have done this as well. However, some people are scared of hurting their new display and do not run the slides unattended for fear that something will go wrong and a static image will be displayed for hours. If you have this fear, read
this article posted by jliedeka.
There are two schools of thought concerning the settings that should be used when performing break-in.
1. Low and slow: Old School
Picture Settings:
Cinema mode
Picture: 50 or less
Brightness: 50 or less
Color: no matter
Tint: no matter
Sharpness: no matter
Color Temp: no matter
Color MGT: OFF
X.V. Color: OFF
C.A.T.S.: OFF
Advanced Picture:
Video NR: OFF
3D Y/C: OFF
Color Matrix: HD
MPEG NR: OFF
Black Level: Light
HD Size: 1 (slightly overscanned)
Pixel Orbiter set to Auto or Force 1
2. Torch: New School (This is the method I utilized, and is the suggested settings if you plan using others SM adjustments.)
Picture Settings:
Picture Mode: Vivid
Contrast: 100
Brightness: 55
Color: 65
Tint: 0
Sharpness: 50
Color Temp: Cool
C.A.T.S: Off
Video NR: Off
Advance Options
Video NR: OFF
3D Y/C: OFF
Color Matrix: HD
MPEG NR: OFF
Black Level: Light
Make sure to set the picture viewer to slide show with no time limit. Be sure to turn off No Signal Shut Off and No Action Shut Off under the advanced Set-Up menu if you are going to run the slide show.
Lastly, I just double checked the files that I linked and did not see a dot in the image nor should there be one…I would not use them if it appears on your PDP as well.
