Triangle Borea BR08 lackluster sound quality & a potential to resolve for it.
  • Thread starter Thread starter Paul Riley
Paul Riley
2
0
1
56
I've had these for 2 weeks, bought heavily discounted from Adorama scratch/dent section of the site, but overall, they're in new like condition minus the defects. Paid $185 for 1 that had slight damage top rear left with vinyl peeling & MDF exposed & $150 for the 2nd speaker for the Tweeter not working, the grill & spikes are missing, but overall, they look brand new.
The 2nd speaker, the tweeter, was not working due to one of the wires not connected. Once connected, out of the box, they were both flat, no body, bass & mid-range lacking warmth & depth.
The mid-range & tweeter did exhibit very nice detail, extension & imagining, but the tonal balance from this point to the 2 woofers were terrible. They sounded bad on all 3 of my Denon's: 2808ci, X4300H & X4500H. Burning them in for 3 days did nothing. Comparing these to my DCM TP260-CH tower speakers & Wharfedale Diamond 230, I knew then something was wrong here because I expected a shootout between the speakers, but the BR08 didn't come close to any of the good aspects of the other speakers...
Tweaking the EQ curve, burn in, room placement all had a nil effect. Out of frustration, I opened up one of the speakers to inspect the insulation & the crossover. Didn't find any issue with the insulation, but I noticed something odd with the crossover.
2 separate PCB's. The main signal arrives at the mid-range crossover pcb and the 2nd pcb is for both tweeter & woofer and is tapping off the mid-range pcb. All of the wires appear to be 12awg from start to finish, but I noticed the wires that connect the 2 pcb's together appear to be 16awg. Those 2 wires looked wimpy. I've soldered 12awg wires in place of those 16awg wires & now they're fuller, bolder, more richer & the tonality with some serious bass is finally there.
If this is the original configuration as far as the crossover wiring & most owners & reviewers are delighted with the sound, imagine the huge potential just by upgrading those 2 wires between the crossovers.
I surmise a robust Amp would mask this issue here versus the equipment I got.
Is there anyone else who thinks their BR08 are lacking in sound? Or is it just me....
I doubt very much that replacing some internal 16AWG with 12AWG made any real difference. I think some expectation bias kicked in there.
  • Agree
Reactions: ryanosaur
I'd simply suggest you get better speakers rather than micro manage details that don't really matter....are these speakers particularly renown ?
Lol, I thought I was getting better speakers or atleast trying something different from what I have now.
Renowned, there's a select few who give them praise for what they're worth & what they accomplish.
Sure you might have, but why did you have these particular expectations for these speakers? You optimizing placement in your room? Hard to know....
Cheap Jack French Junk.
