anamorphic96
There is no such thing as THX certified cables in movie theatres. It is standard 10 or 12 gauge wire. Nothing special about it.Sheep said:Well I think THX theaters use extremely long runs. Maybe they need to have low losses....
SheepStar
In commercial theatres alot of the THX standards have to do with -
1. The baffle wall behind the screen.
2. Acoustics in the auditorium. In a properly built THX auditorium you should never here any outside noise from the lobby and you should never here any of the HVAC equipment.
3. The THX crossover cards for bi-amping.
4. Amps should be built to THX specs along with speakers.
5. Equalized with R2 software. ( 4 microphones placed in specific areas. )
These are the main items.
There is no special processing in a THX equipped theatre.
