The response at 20 kHz does drop significantly whne used with low-Z speakers. Trust me: you can hear it. The other ICEpower modules have a similar effect, but to a much less degree.
As the ICEpower modules were created with powered loudspeaker systmes in mind, I am not sure that they intended this particular one for full-range applications. You will note that the stand-alone version of the 1000W module is only useful to 6 kHz (or so).
As for how it compares to the other modules............sonically:
We feel that it does have more "slam" in the bottom, but the midrange does not sound different from the others. We concluded that it is a strong candidate for (sub-) woofer applications, but we have reservations in making one available for full-range applications.
As for this claim:
If I understand it correctly, the ASP based amps have one big weakness: The voltage & frequency is hardwired by design. I noticed that 120 volt ASP modules are limited to a 55-65Hz range in mains frequency. This means that an amp bought in the US will be worthless in Europe (and vice versa, I assume). The voltage can be corrected with a transformer, but not the frequency.
You don't understand it correctly. That is what the design ratings are for 120V operation. The same module is rated for 45-55 Hz at 230 VAC operation.
If you had taken the time to actually look at the complete specs, instead of guessing, you would have seen that can run from anywhere between 90-132 VAC and 190-265 VAC simply by taking out the fuse, changing it to the proper rated one, and inserting it into the corresponding orientation on the PCB.
I hate to point out that the price of any amp drops like a rock once you buy it. Regardless of whatever technology it uses. I doubt anyone buys any current piece of electronics......amp, computer, whatever..........with an eye towards investment.
BTW.......if it makes anyone feel better, we also offer products using Hypex modules. Take your pick.
