silversurfer said:
Can you point me to where you have read this? I have read differently.
Most notably we have the objective fact. The ASP1000 drops almost a decibel at 20kHz. The ASP500 only drops a quarter of a decibel, and the ASP250 has an even more linear curve. PS Audio has thankfully published charts:
http://www.psaudio.com/products/gca_amplifier_specifications.asp
I'm taking about the sound quality at "normal" listening levels, say around 1W. It is true that the ASP1000 is said to have lower distorsion when you push it really hard. However, this hardly represents normal listening when it comes to the typical audiophile.
Since Sleestack is using room correctioning, it will take care of the ASP1000 non-linearity, so it is probably a non-issue in his system. However, people without correctioning or EQ, that are doing A-B comparisons may definitely experience "dull highs" in the ASP1000. Here's a review of the ASP1000 based Rotel 1092:
http://www.htguide.com/forum/showthread.php4?t=19400
This is what Paul McGowan says in the PS AUdio forum discussing the three PS Audio amps GCA-100 (ASP250) ,GCA-250 (ASP500), and GCA-500 (ASP1000):
"The output filtering on the bigger amps is more, well, intense? That's why we've said all along that if you listen to either of the bigger two amps vs. the smaller one, the 100 has a better top end - by a smidge."
Sure enough, the ASP250 based GCC-100 gets a great review in Stereophile:
http://www.stereophile.com/integratedamps/106ps/
Peter
