I'm just back from vacation and saw Gene pointed me to this thread. I'll keep my answer short, touching on a few points I saw mentioned during the one minute (sorry short on time!!!) spent reviewing the thread.
The point about the 60mph car is exactly made. With more or less ohmic speakers, a well designed open loop amplifier with a stable supply sounds fine. If it floats your boat... Point is, one can get equal or better results more cheaply and reliably (ie also in difficult loads) if one allows oneself to apply feedback. It removes the requirement for a stabilised supply (effectively reducing cost and increasing power efficiency), allows the power stage to be optimised for efficiency and EMI rather than distortion and potentially (if the feedback is taken after the output filter) guarantees a flat frequency respons.
The IcePower modules are all analogue and use feedback (so far only partially after the output filter). Although sometimes the company calls the amplifiers digital (popular verbage, goes well with the clientele), the designer makes no bones about the fact that the amplifiers are analogue and that this design method is preferable on technical grounds. There is total agreement between myself and KN on this.
Like myself, the designer of the TacT Millennium, Lars Risbo (now mainly active for TI), likes toying with all kinds of topologies and prefers to draw his conclusions based on experience and fact, not ideology. He's recently designed a new TacT -oops- Lungdorf amplifier which, although sold as "digital" for commercial reasons, is highly analogue and uses a most innovative feedback and modulator design that is bound to place this amp on the map in a serious way. The design is outlined in his excellent AES paper (preprint 6693, see
http://www.aes.org/events/120/papers/session.cfm?code=P8). Ironically, just after the designer of world's first commercial "all-digital" amp showed how to improve modulator linearity in an analogue circuit, I went on to present a *digital* modulator (preprint 6694) with improved behaviour in the same respect. Much to our delight, we both explained the same problem, arrived at the same conclusions, but got round it in very different ways (my proposed solution is equally amenable to analogue implementation btw).
This particular paper session started with a completely rewritten re-run (preprint 6690) of the argument made in the audioholics article that is the object of this thread. I hope it explains the rationale behind some of my assertions with sufficient clarity as to make obvious that the arguments are technical, not ideological in nature.
For copyright reasons (the AES needs to get its funds from somewhere) I cannot repost the preprint in its exact AES format. A reformatted (but otherwise unedited) version can be found at
http://www.hypex.nl/docs/allamps hypex layout.pdf . Note the co-authorship between competitors, as another illustration that the class D world is way too small for gripes among colleagues.
Likewise, several designers of class D products and chips who have all invested in "digital" designs have privately stated their agreement with this paper, but you will understand that they have the right to publicly defend their investment in the way they see fit. Note though how several manufacturers are now slowly introducing partial feedback measures into their designs. Feedback (and hence analogue processing) is gaining ground, but those who previously jumped on the "all digital" bandwagon with much ado will do so more quietly than those who have started off analogue in the first place. In general, it's always better to define or change one's opinions to reflect reality rather than to try doing the converse, but often pre-existing commercial interests make it hard to do about-turns just like that. In a world riddled with preconceptions (and the insistent belief that all thinkable opinions are equal in value) it can cost a company dearly to do so too obviously.
In closing I'd like to clarify my professional status. I worked for Philips (division changes name constantly) from 1995 to early 2005. During this period I designed several class D circuits, both analogue and digital, including the UcD circuit for which the company holds the patent. I'm now an employee at Hypex. I don't do consulting work. If there's one way to land into an IP quagmire it's consultancy.
I've still some 200 emails to work through so I'm leaving it here. I might check the thread later but I'll only reply to questions to which the answer hasn't been given in this reply or in the referenced papers.
