GlocksRock
I guess I may have to search for an older version of TMT if this ends up working for me.
Thank you!Dont have The Rock, but I just tried Spider-man 3 with TMT2.
Its has PCM 16/48 and TrueHD 24/48. Both came out fine.
Though, why they put in PCM 16 with TrueHD 24-bit is beyond me.
Hello Everyone,
As I have understood and experienced. it is possible to get HD Audio without these fancy cards like Xonar.
...as long as your happy with PCM at the same rate as the original being pushed out to your reciever and don't care about the fancy TrueHD/HD MA lights.
If you use TMT3, without Xonar, it will decode and downsample TrueHD/HD MA to PCM 16/48 over HDMI. So if you have DTS HD MA in 24/48 (e.g. Day After Tomorrow), it goes out as PCM 16/48. Some loss.
However, if you use older versions of TMT (2.x.125 or lesser), they did not downsample. They decode and output at the same rate e.g. 24/48 above.
I have tried such a version and can confirm that output was 24/48 (using ReClock).
regards
I had tested PowerDVD 9. It was giving 24/48, but the channels were messed up. I could hear dialog from left/right (one particular scene I used for reference).Is there any way you can test PowerDVD9 to see if it's PCM output is 16/48 or 24/48?
I read that it would have been due to AACS (or whatever) requirements. They are required to downsample HD Audio to 16/48 if there is no secure path (something called PAP) is not available. (which is'nt available without Xonar HDAV e.g.)I wonder what the reason is for the downsampling, and how much of a difference it makes. I'm guessing the overall effect of the tracks that do get downsampled isn't that noticeable.
That Asus Xonar card comes with TMT2.PAP is protected audio path. I found an older copy of TMT that should allow 24/48 to be passed, so hopefully both TMT 2 and TMT3 can be installed at the same time, but if not I hope TMT 2 will be compatible with some of the newer titles. I guess I'll be finding out soon enough. I'm just excited to now have lossless audio from the PC instead of bitstreaming the standard dd/dts track.
I also wanted to add that along with Dolby TrueHD, 5.1 LPCM sounds awesome (no dynamic range compression).Why is it that on TMT, you can configure the Dolby TrueHD settings, but there is NOT even a setting available for DTS-HD?
For Dolby Digital/Dolby Digital Plus, what should you set the Dynamic Range Compression to? Line-Out?
The reason I ask is because when I play back TrueHD, the sound is AWESOME.
But when I let TMT decode DD or DTS-HD, I get this "compressed-like" audio?
Are DTS/DTS-HD & DD/DD+ all compressed (dynamic range)?
Max bandwidth of S/PDIF is 1.5Mbps as far as I know. Thats why most if not all of the DTS mixes are 1.5Mbps bitrate as this is the most that the interface/cabling will support.Does anyone here actually know the maximum bandwidth of S/PDIF? It seems to be undefined, as it is possible to pass 2 channels of 24/192 over it apparently, but no reciever supports it. My Sony one automatically outputs as stereo only if you try to pass 96Khz or above over it.
What I'm trying to say is that it could be possible to output 5.1 PCM of 24/48 over S/PDIF as 48000 x 24 x 6 (channels) = 6912000 bits = 6.9Mbs. I think thats in the bandwidth range of S/PDIF as 192000 x 24 x 2 = 9.1Mbs.
All that I would then need is the TrueHD or DTS MA to be decoded to PCM by my PC or PS3 and put it out through S/PDIF optical or coax to my reciever. The only problem I could see is that if I get a bluray with a higher sample rate as my reciever will not support it then. I would need a digital lowpass filter to downsample it.
Are most blurays 24/48?
Where do you find the settings for TrueHD? I don't see them anyhwere.Why is it that on TMT, you can configure the Dolby TrueHD settings, but there is NOT even a setting available for DTS-HD?
Under ADVANCED Audio setting.Where do you find the settings for TrueHD? I don't see them anyhwere.
