The Best Amplifier We've Ever Measured? - NAD M23
haraldo
haraldo
Someone got out of bed on the wrong foot here ;)
I gotta hear this amp, test at home :cool:
Mikado463
Mikado463
Yes it matters. Why would I pay a premium for an audio product if I cannot hear what that premium provides?
No, a premium is the price of the Levinson, $3400 is not a premium IMO but regardless, if for you it is then fine stick with what you are comfortable with !
buckchester
Wow, touchy bunch some of you are! All I asked was whether those differences were audible or not. I think most would agree that's a relevant question for an audio product. ;)
Steve81
Steve81
Audioholics Five-0
It’s frowned upon to discuss other products in a review thread. In this case, it’s like bashing a Porsche because your Civic gets you to work just fine. Sure, there are differences, but you still have to drive the speed limit, so what’s the point???
Would you mind elaborating a little? Because I read ASR's review of the 2220 and it looks similar to this Nad to me? Even where the Nad measures better, is that even audible?
Over 80db improvement in Signal to noise ratio, will definitely be audible. This is especially true as the number of channels rise.
At the moment these units are far too expensive for most to consider using in multichannel AV systems. At the moment development costs are being paid off.
In the long run these amps should be much cheaper to produce. Even better they waste less power and don't make much heat. So we will progress to active speakers being the rule. Passive crossovers waste at least 50% of the amp power in most passive speakers. In addition, passive crossovers are highly limited in what you can achieve, for one thing you can only cut and not boost power. So if you have a dip in response, you can only cut either side and waste more power. They are also awash in time smear. The components are bulky and expensive if you use high quality low resistance inductors and avoid electrolytic caps.
The real "pay dirt" from these class D amps, will be much improved speakers, and those differences will be highly obvious and glaring. Speaker deficiencies are so prevalent, it makes even significant improvements in power amps inaudible.
We will see the death of the stand alone power amp, it will come eventually.
Steve81
Steve81
Audioholics Five-0
They just need to make it happen with a single cable, something standardized that could transfer a digital signal and power over the same line. We do that already with some things (USB, PoE, etc), so not sure why they don’t do it here.
The digital is no problem. The powering voltage will be 120 in the US and 240 volts in other jurisdictions. You could not have centralized DC supply as there are high and low voltage sections. So they will be code issues. This would not be like running speaker wire. In many case it will not be a huge problem to add AC outlets at speaker locations.
Steve81
Steve81
Audioholics Five-0
I wasn’t thinking a central DC supply, just a 120V run with the digital signal riding on top. The receiver would essentially be a glorified power strip at that point. Not workable?
It could be, but there would be red tape. You would need a combined Romex and Cat 6 cable. That would require regulatory approval and still need to be in wall.
It's not audible - THD+N of 0.0003% vs 0.003% vs 0.03%, especially at normal volume, distance and most environments.
But we all have our reasons. :D
Some will always stick to separates and some will always stick to big established brands, especially if the SINAD is more than 90dB or 100dB.
But like Steve says, probably not a great idea to crash a party and ask these questions. :D
Now if it were another separate thread, especially your own thread (and party), it would be just fine. :D
Alex2507
Alex2507
Looks like this sentence started off on the wrong foot and got out of bed on the wrong side. You're gonna make me dyslexic in English with the mixed metaphors.
gene
gene
Audioholics Master Chief
Administrator
OK, but how audible are those differences?
Depends on the efficiency of your speakers and how closely you sit near them. I can hear hiss a few feet away with amps that measure like the Outlaw when connected to speakers > 90dB sensitivity at very low listening levels or just sitting in idle.
dlaloum
There's a big gap between State of the Art, and individual audibility thresholds!!
Premium kit, is almost always far beyond any audibility threshold.... a bit like the way Rolls Royce used to advertise the power of their engines "Adequate under any circumstances"... and Aston Martin : " More than Adequate under any circumstances".
Sometimes it's just about having the confidence that audibility thresholds are far beyond where they would be a concern.
buckchester
I have Revel F208s with the Outlaw amps, sit about 8-9 feet. I play loud. I hear no hiss. Ever.
dlaloum
We already have systems that allow ethernet network signals to pass over a power cable.
No reason you couldn't run one of several Audio over Ethernet standards (streaming) over your power cable.
The technology is there today - creating a standard and getting a consortium of sufficiently influential audio manufacturers involved, would be more of a challenge!
dlaloum
Not saying this is the case here - but in many (most) cases where there have been hiss issues in a setup - I have found them to be related (or at least substantially exacerbated) by gain mismatches between pre and power
gene
gene
Administrator
It's all relative to where it's being amplified. Adding gain adds noise.
So that's consistent with what Gene said, "when connected to speakers > 90dB sensitivity at very low listening levels or just sitting in idle."
The F208's sensitivity is < 90 dB, not >90 dB as measured by Stereophile and you said you played loud, so the M2220's THD+N is good enough for your use but probably not good enough for someone who uses >92 dB speakers and listen mostly to classical music that has a lot of quiet passages and gaps between movements and does not want to hear any noise.:)
