Subwoofer recommendations
ryanosaur
ryanosaur
İ want to hear all opinions if i can use double gem instead. 2X10“ woofers is like 1Χ14’’.
i know xtz looks better but other can be a good almost equal solution B.
So far everyone is saying stick with the XTZ. :)
ryanosaur
ryanosaur
Yes. The XTZ. We already talked about it and we all agreed on that in your other thread.
I know... *shakes head disapprovingly
I've been watching.
Stay with us, @killbill13. :) Stay. With. Us. Here.
The small box is for wives that don't get it. Do not be a wife that doesn't get it! :p
:cool:
killbill13
killbill13
Can someone considering this:
and answer a question:
2pieces X 8.17 (non edge) https://www.xtzsound.eu/support/sub-8-17
or 1X 12.17 edge. https://www.xtzsound.eu/product/sub-12-17-edge
someone must check the manual is available online. I dont understand spl’s and all this numbers.
i live in apartment Also.
Not sure what your question is....
tyhjaarpa
tyhjaarpa
My alternative can be a Double Gem on the floor. its a space saver. And more placement options Because its thin and long.
its not shipped yet, i can still do it.
Thanks. İ want to hear more opinions if i can use double gem instead. 2X10“ woofers is like 1Χ14’’.
what @tyhjaarpa has to say. Or @KEW @lovinthehd @William Lemmerhirt
You have really big space to fill and only real option is to get big subwoofer that is able to fill it. 10" Double Gem just is not for this task without talking about 8" 8.17 that would struggle even more in your given space. Dual subs will have more even output but it won't solve your problem of big space to fill, it will help to some degree but it wont be enough in your given space. In such big space your only option to achieve good output is to have big subwoofer that can do so. You could buy 2 smaller subs, yes, but will you get the output you are looking from your subwoofer? Most likely not.
