Subwoofer only works during EQ phase.
  • Thread starter Inexorabletruth
  • Start date
I
Inexorabletruth
My setup is pretty straightforward, and not exactly cutting edge, so I don't get why I'm having this issue:
Reciever: ONKYO TX-NR676
Speakers (2 Bookshelves only): Polk T15
Subwoofer: Klipsch R-120SW
The receiver has a port upfront where you can plug in a PZM mic and it'll set up the EQ for you. During this time, it tests all channels, including the amp, and then plays a 5 second audio sample.
All that sounds great. But...
The instant it goes back to whatever I was listening to before the set-up, the subwoofer goes silent.
It's still on, and still kicks when I test the cable... Just the receiver quits sending a signal to it.
The sub never gave me this problem until I made one change:
I routed sound back up to the TV so I could plug a couple of gamer headphones to the TV's RCA out ports, but I have no idea how that would cause the sub to only work during EQ.
Anyone wanna weigh in?
I
Inexorabletruth
Are your speakers set to large or small?
I think small?
While I tried figuring out how to know for sure, the sub started working. But then, the headphones quit working.
And when I tried to fix it, both quit working.
I got the sub working again, but I have no idea how. I know when I started, option 2 (Speakers) was greyed out and inaccessible. But now it's accessible. But, again, my headphones don't work now, which I get that audio from the TV, because I can't make Zone 2 work. So that means no more audio is feeding into the TV.
I assume big would look like towers. I'm so sorry. Home theater got too smart for me.
Pogre
Pogre
I think small?
If they're set to large it bypasses bass management and your sub might not get a signal at all. Room correction on a lot of avrs automatically sets speakers to large if they're even slightly bass capable. Small is where they should be set when using a sub.
How do you have everything hooked up? Are you using ARC? That can be buggy. I don't like using my TV as a source for that reason. I plug everything into my avr and basically just use my TV as a monitor
I
Inexorabletruth
Ok... I just checked that and saw that ARC was disabled.
Fun fact... I just enabled it and everything started working at once, which had upset my neighbors, because I had forgot Is turned everything to max. But we're cool. I'm playing Corelli: Concerto Grosso in D. So, it's loud at... But also soothing.
Thank you all for your help!!
