hawke : <font color='#000000'>Strange.. usually, you'd just run a single cable and then split the end at the subwoofer with a Y-cable to feed into both inputs of your subwoofer... Your scheme seems to indicate that they ran two cable runs and joined the end at your receiver.
If the other end isn't terminated with RCAs, you'll need to do that, provided you are using line-level inputs to your subwoofer.
See
this article for more info.</font>
