I'm confused.com now
80? Or full up to the max
Your speaker array is not full range barely getting into the 70 Hz arena; therefore, setting sub at 80 Hz, assuming the sub will produce tone up to 80 Hz smoothly, and also assuming your center and surrounds can be filtered at 80 Hz and mains at 60Hz, you will have a condition which will get you off to a good start with it all. You could also just set mains, center, and surrounds to receive full frequency and that would get you off to a good start too; but, speakers would then be producing tone into the subwoofer arena, which strains the amp and could produce some distortion. Also note, the higher frequency the sub is set to the more directional it will become; that's to say, bass will be heard as coming from the place where you've placed the sub, so setting the sub higher than 80 Hz could be problematic. And, setting sub at 60Hz is problematic too, since you then have a frequency hole between 60 and 80Hz which will make for a very strange listening experience. Now, even when you have it set up properly to sound great at an average listening level, you will still need to adjust bass volume when listening at low volume and as well at a high volume for the bass to fit in with higher frequencies. If you don't adjust at low or high volume the bass at low volume will lose its presence and at high volume it will overwhelm the experience. From reading your earlier posts it appears all you need to do initially is set mains to crossover/filter at 60Hz and set your sub to 80Hz, then, get the SPL meter out to match volume of speakers. That's it.
