Setting speakers to Large and also crossover to 60 hz and above with LFE + MAIN
  • Thread starter Thread starter Sachb
After Endless, Testing I have settled for:
1) Crossover: 80 hz (ALL)
Speakers: Small
LFE: LFE only
2)For music, I do the following:
MultiEQ XT: L/R Bypass
Dynamic EQ: On
-Reference Level Offset: 10 db or 15 db
Dynamic Volume: Off
For movies or TV shows: I do the following:
MultiEQ XT: Reference
Dynamic EQ: On
Dynamic Volume: Light
Going for this settings gives me best possible sound for both movies and music. Although I could us Dynamic Volume for music too.
A short sample of my Music system, sorry for the shakiness:
I’m gonna put in a recommendation to move those mains off to the sides. At least a couple feet. You’ll get so much better imaging, and a much larger soundstage.
Also, curious(as I don’t use it) what you particularly like about dynamic volume? Neighbors?
I will soon buy a pair of stands for those. I like Dynamic volume because I usually i keep my volume below 50 on the Denon, so it kinda boosts the vocals and mids.
Ok. I can see how DV works for you. Btw, once you move your speakers out, I think you’ll find a whole new world of sound.
  • Like
  • Agree
Reactions: snakeeyes and Sachb
Reference level offset as suggested by Audyssey should be set to 0 for movies. which actually allows for more dynamics and bass. It’s suggested for music to set the reference level offset to 10db or 15db because music is mixed at a higher level then movies. Selecting a higher dB offset is actually subtracting not adding to the sound. Try it play some bass heavy music and cycle through 0 5 10 15 and see what happens.
The multeq App is worth the cost actually.
Now it's sounding 80% of what the Elacs can do.
Once I get the stands it should sound close to 90%.
Non fatigue and sweet sounding system.
Sent from my LM-G710 using Tapatalk
  • Like
Reactions: ParisB
The fun part is you get to start from scratch once you put them on stands. ;)
  • Like
  • Funny
Reactions: Sachb and ryanosaur
True, but I will be buying the stands later, as I'll be shifting to a new apartment soon.
  • Like
Reactions: everettT
