Sennheiser Momentum On-Ear wired Headphone Speaker type?
  • Thread starter Thread starter mittsthetford
mittsthetford
2
0
1
41
Hello,
I have had a set of the Sennheiser Momentum On-Ear wired Headphone since about 2013 and loved them dearly. I think I recently might have blown out one of the speakers and am wondering if it is possible to order a replacement speaker. More importantly, does anyone know how I would figure out what type of speaker it is or where to order them from?
I'm a newbie here so any help would be greatly appreciated.
Take care!
Matt
Hello,
Take care!
Matt
Chances are it is the wiring. So get you multimeter out and check continuity.
Hello,
Take care!
Matt
I would agree with TLS, it is probably the wiring, so worth checking out first.
Service and Spare Parts Link Bellow
Headphones | Sennheiser
  • I own the momentum 4, which I bought because I thought I left my Momentum 2 on the plane
  • Fast Forward a year, found them in my basement, apparently, I put them in the retail box for some reason, I am pretty OCD with my electronics
  • I like the momentum 2 more than the 4 looks wise, I wouldn't have upgraded, but I do like the 4s now
  • They are not going to win any awards for sound quality, but do sound very good and the noise canceling for my plane travel is excellent.
Thanks for the reply! I tried that and everything was functioning perfectly. It does not appear to be the wiring.
What led to this in the first place was that I tried using them with my guitar amp but didn't see a headphone jack so plugged them into the 8 ohm combo speaker outlet, which was a rookie mistake. Perhaps I played it too loud because afterwards when I plugged them into a laptop to use them normally, the left side only works at about 25% of the right.
What makes it a bit more bizarre is when they are plugged into the amp (through a 1/4" adapter), the right side works perfectly fine. If I pull the cord out a bit, the left side works perfectly fine.
I mention this because the left speaker is capable of functioning at 100% capacity but only in a specific circumstance
