I don't know that. I cannot tell that this sub is ported from just listening to it.
I believe that 100%. In blind tests where peoples biases are removed from the equation, people cannot tell the difference in sound between ported and sealed subs. What I believe is the issue, is that if someone firmly
believes that sealed subs are "tighter", "faster", more "accurate" or whatever(none of which are real terms), then they will hear a difference. Just like if someone goes out and spends thousands of dollars on an expensive "audiophile" amp, they are convinced it is going to sound better, therefore it will.
But again, my comment was that servo has nothing to do with the box size of a sealed sub, or the difference in how ported and sealed subs roll off at low frequency. They are two totally different and unrelated paramaters. Just like the color does not change the port tune.
Now having said that, it may be possible that your servo control may be causing a better sound quality due to lower distortion. But being ported or sealed is likely to make no actual difference in sound quality. Do all subs sound the same...no, especially if they have a poor FR or poor build quality, poorly tuned etc etc. But two well built subs playing within their abilities will not be identifiable in a blind test when level matched etc. A good example would be a SB2000 and a PB2000.
On a related but slightly different topic, I think sealed subs have gotten the title of "musical" largely through marketing.
Lets assume the following, given two similar subs:
Sealed and ported will sound about the same on music.
Ported will have 2-3 times the output, or more, for movies.
If size is not a constraint, ported is superior for movies or dual purpose movies and music.
Sealed therefore, is generally equivalent for music, inferior for movies.
As a company selling its products through marketing, do you want to advertise your sealed sub as "good for music, inferior for movies", or just label it as "musical"? Someone shopping for a sub for their two channel listening does not want to buy a sub that is "inferior for movies", they want one that is "musical". Is it musical? Of course, just like a ported sub is. But not more so.
