Sanity check: Bad Sub ? (REW Sweep results)
  • Thread starter Thread starter Linwood
This is a safe space. We don't judge.
You know, there's a difference in judging out loud and internally. ;)
Though I also don't really need a "butt shaker" whatever that is. If it's like a salt shaker and scatters butts all over the place... pass.
Though @TLS Guy has been known to "judge" speakers, it's part of why I now have a room full of big cardboard boxes. :)
He has butt shakers (subs), four total 10" Seas Excel drivers in his left and right speakers, that's the primary reason he doesn't need separate subs, not to mention his surround speakers are very capable.
I think most use the term for something more along the lines of a tactile transducer like these https://thebuttkicker.com/
I was joking about shaking buts around on the floor, the meaning was fairly obvious.
I was actually referring to these ghastly devices, or similar.
It is these transmission lines that need no help.
Since you are relatively new here, you likely have not seen those pictures before.
I have not. I'm not sure seeing the setup is a nice thing or not. :)
Quite the setup. Thank you.
  • Funny
Reactions: TLS Guy
That is why I hesitated to show you. However, you do seem to have add a rapidly addictive entry. I do think you have the basis of a very nice system. Because of your addiction I hesitate to show you my power amp case that powers it all.
LOL since when have you been shy about such?
Just a habit with gear...
I tried to keep the boxes everything but a few non speakers boxes got tossed out. gotta have your own place to save them. Then my lg Blu-ray player broke because instead of it being in the box that got tossed the power cable was crammed in a plastic box. Or old age broke it.
how tall are those towers diy is probably the only way to get transmission lines there so rarely built it seems for mass market . So much bass you don’t need subs is impressive even for high end drivers 10” + are uncommon also these days.
The drivers are 10" SEAS metal cone drivers, two in each bass line. These have an Fs of 20 Hz and ideal Thiel/Small parameters for use in transmission lines. However the upper of the two 10 drivers, is driven above sub range to handle the baffle step compensation for the mid drivers. This BSC is continuously variable so it can be set precisely for room and speaker position. This is possible as the speakers are active triamped. The center speaker also has variable BSC. Pipes are very efficient at converting air pressure to air displacement, so the bass drivers do not need high displacement, although they are no slouches in this regard.
Total enclosure height on the right and left main speakers is 5'9".
Their inspiration was the famed dual transmission lines custom designed and built for the BBC studios Maida Vale. This studio no longer exists as the BBC had to sell those studios to raise cash. I did manage to purchase two of the custom Quad 405-II power amp cards when they appeared on eBay, just for nostalgic reasons.
The rear dual lines are even taller, at 6'2 1/4". The bass drivers are two very capable KEF B139 drivers, which are now capable of handling some of the LFE channel as those B 139 drivers are very capable.
As far as I know, the BBC lines and mine are the only dual transmission lines ever designed and built. There may be others but I don't know of them.
So, lets taunt Lovin, with a picture of the 3,200 watt power amp case with 18 audio channels.
  • Like
Reactions: 1Randy and Kingnoob
Do you have a requirement to notify the nearest seismic monitoring station before turning it up about 30% or so?
Or do you just cause false positive earthquakes and laugh?
I doubt I play louder than most, but the crescendos don't get clipped. The issue is that when a sound doubles in loudness, then the amp power has to go up ten fold. So to really reproduce a large orchestra and possible a large choir and huge organ, like the Voice of Jupiter thrown in, you have a huge range of spls, in short spaces of time. So, truly realistic reproduction takes a lot of power on occasions, and you need to leave plenty of head room. Since I built this system nearly 20 years ago now, it is the only one I have never run out of head room. It has taken literally a lifetime to get to where I am truly satisfied with a system.
So 3db requires ten times the watts? I had no idea it worked like that. Why would that be?
Because of the perception of human hearing. It is a log scale because of that. The db scale in not linear but log to the base 10.
A 3db increase requires doubling of amp power. When we perceive the SPL as twice as loud, then that is equivalent to a 10dB increase (One Bell louder) hence10 times the amp power.
  • Like
Reactions: everettT
I was aware of the scale, I thought he was saying twice as loud (which I interpreted as 3db) was 10 times the power. But you are calling twice as loud 10db (which perceptually sounds about right). So... got it.
