I Imureh Audioholic Intern Jan 3, 2007 46 0 8 Dec 6, 2019 #21 Slickman said: Those numbers are from revision 1 of the FV18. The new FV18 revision 2 has 4"' ports instead of 3.5" and you can also get a paper cone version which adds even more output. Click to expand... You are correct. Brian has confirmed that below 40hz the version tested at databass has identical performance to the rev 2 paper cone and above 40hz the paper cone has +3db more output. Sent from my iPhone using Tapatalk
R reggieburris Enthusiast Dec 23, 2020 12 0 1 63 Jan 10, 2022 #22 Years later, I just purchased dual FV18s and have dual FV15HPs en route. Old tech in 2022 that still sounds pleasant. Reactions: Danzilla31
G genesound Enthusiast Oct 30, 2005 12 0 1 Oct 9, 2023 #23 Dean1219 said: Data-bass.com has run the attribute charts on these subs. Rythmik Audio, FV25HP Rythmik Audio, FV18 Rythmik Audio, F18 Click to expand... Not anymore
everettT Audioholic Spartan Apr 7, 2016 5,695 0 113 61 Oct 9, 2023 #24 genesound said: Not anymore Click to expand... Web archive is available and the 2010 data is available here. CEA-2010 Max Burst docs.google.com Reactions: its phillip
lovinthehd Audioholic Jedi Sep 11, 2012 44,890 0 113 Oakridge, OR Oct 9, 2023 #25 FWIW sweetchaos on ASR has a pretty good database going, too https://www.audiosciencereview.com/forum/index.php?threads/subwoofer-comparison.20494/ Reactions: lockonS, everettT and its phillip
L lockonS Audiophyte Mar 18, 2024 3 0 1 29 Mar 18, 2024 #26 Would Audioholics be able to get the FV18 & FV15HP back in for review and measurements 2024? Since then they also had the G25HP developed and I'm curious how that stacks up to the perlisten offerings as well.
