I am planning on replacing my old Polk PSW350 with an SVS sub, most likely the PB-1000, and have a couple of questions before I do so, the second of which will touch on moving the Polk to our separate two-channel system...
First -- is the move from the PSW350 (100 watt output) to the PB-1000 going to be noticeable in terms of output and tactile bass response? This sub will be running alongside Polk RTi12 mains in a 5.1 setup, with the RTis crossed over at 60Hz so they can "flex their muscles" a bit as big floor-standing towers, but will the move to the SVS be worth it? If not, which SVS would be recommended to move up to....something in a higher series, perhaps the 2000 or 3000? The listening space is a typical living room without vaulted ceilings, with a 12-foot distance between the front stage and the main seating position.
Secondly -- I'd like to repurpose the Polk for our upstairs two-channel system, as that setup has an Onkyo two-channel stereo receiver powering it which boasts a dedicated sub preout. However, because this is a two-channel model, there is no bass management on the Onkyo...so how would I get the PSW350 dialed in here? There is a sub preout on the receiver, as I said, so how would dialing the crossover in work in this scenario? I was under the impression that once something is physically connected to the preout jack of a powered sub, its internal crossover is immediately bypassed -- so how would I dial in the bass outside of the volume knob of the Polk? Is it just a plug-and-play situation, simply working in conjunction with the main speakers (in this case a pair of Infinity Primus 363 towers)?
