N
NorCalRP
I'm going to pick it up Thursday. I sure am glad for your insight. I do want to make sure on the configuration. Your advice is for Max output, rather than Max extension. The stated response of the SVS dips to 19hz, where as the low end on the HSU is 18hz. Is the setting you suggest going to give me the most similar response curves?The PB-1000 would not terrible to mate with a VTF-3 mk4 because SVS tends to place strict limits on the amount of distortion they can produce. The SVS sub will not be able to produce that much bad noise. The only problem is mismatched tuning points below the tuning frequency of the highest tuned sub. Thankfully the VTF-3 with both ports open in EQ2 mode will have a very similar response and tuning point to the PB-1000. I have the predecessor to the VTF-3 mk4, I have some mk3s, and I adore the design, by the way. It is a large sub though, so make sure you understand how big it is before you pull the trigger.
Also, when I originally set the system up I used the manual setup. I then ran Audyssey, and oh boy what a difference. I'm planning on setting all the sub controls to flat/neutral (?), and then run Audyssey again. Do you think this is the way to go?
