Jordan
since you elaborated some more on your set up. Setting the speakers to small is correct and turning the subs crossover all the way up disables it. The receiver you mentioned I'm not familiar with, but most newer receivers have an adjustable crossover option, if yours doesn't don't worry. The receiver will know the default setting and then send all signals below its set point to the sub and above to the speaker. Most people set the x-over between 80-100 Hz it's all a matter of taste. As far as the static or noise goes, I think a proper sub cable will help and any further question just ask.
Good luck, Billy p
