Buckeyefan 1 said:
Do the drivers go into "convulsions" when pushed?
(shakes his head) Oh Buckeyefan 1. Really.
To be honest, I couldn't tell you. I've only a couple of times felt the main driver during particularly bass intensive pieces of a DVD. The Matrix Reloaded springs to mind where near the end, the film cuts from the Key-Maker decribing how to overcome all the security systems of a building to the window panes of a skyscraper cracking. The first time I heard those panels cracking I thought I must be hammering my sub, so I replayed the piece and felt the driver. It was only vibrating; no significant excursion at all. Since then, I tend not to worry about it. For reference, I tend to listen to DVDs with my volume set between -10 and -15dB.
Update:
I've just played 'the Darla scene' from Finding Nemo (known I believe to punish subs). I know this sounds like I am bragging, but honestly, nope. Still nothing I would call excessive.
zumbo said:
$5990.00 to $9990.00 Ouch!
Where does your system fall into this?
Duffinator's first link has the RRP spot-on. Using todays exchange rate of 1.771 against £3490 gives $6180. Plus stands for the surrounds at 1.771 times £200 gives $354, and a total of US$6534, though I paid less since I bought my entire system at the same time.
