Ben,
That system looks outstanding in your room. I bet you hate to put the grills on.
That sub is really nice. I didn't think it was that large. The rubber/foam surround is massive. Does that sub hit hard, or play deep (if you had to lean towards one characteristic)? What do the controls on the back of it look like? I've never seen the plate amp.
I had assumed that setup was more for HT. It appears it's also great for music. I know you need some break in time, and since you have a little one, probably can't jam like you used to.
Let us know how it does with music.
Did the wife know exactly how much you dropped on that 7.1? Was she amazed when it was setup the bang for the buck?
Finally, do you have your rear surrounds backwards? I would think the effect would be greater if the tweeters were facing out. Does the manual say to face them in?
Thanks for all the pictures. They are great!
