buckeyefan1,
thanks for the explanation, lets use actual examples to check if i understand ...
assuming we use the rxv1500 amp
and the yamaha set 777, 555, 333, 444
1) the 1500 has a max of 170w x 7 ; a nominal of 120 x 7 ; and a clean wattage of around 50?
2) since the 1500 churns out the above wattages at 8 ohms and the yamaha speaker set receives 6 ohms at 100 watts except for the rear surround at 60w, so is this amp good for this set?
3) assuming the budget is a bit lower than how much this speaker set is... can i use the 555's as 2 front LR speakers? the 333's as rear LR? and the 444 as center?
4) btw, isnt there a rear center channel?
