Hi AcuDefTechGuy, thank you for your reply. I am now wary of buying a new receiver without a good source of recommendation. I bought that Sony receiver for $250, assuming that 135W per channel was sufficient to drive my speakers. It's not that I went too cheap, though I was on the low range. I hope you understand my frustration with Sony.
Also, though the specs say 135W x2, and it doesn't deliver, I am wondering (out loud) if theres anything else I should look at in the specs prior to buying a new receiver!! Once bitten, twice shy.... is where I am at now.
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I am sure Sony does have some great receivers, but would like to know if it's a hit or miss situation with them or any other receivers, or if a particular spec will aid me to realize if the receiver i am looking at is worth it.
I shall look tonight and let you know if I can find a Speaker Channel Level in the receiver and the outcome.
Also another question (probably a dumb one),what factor pointed you to the possibility of 50WPCX 2Ch was being delivered as opposed to the stated 135WPC initially specified. As stated earlier I am a newbie, and would like to learn what to look out for.
