Pioneer vsx1015tx/JBL Northridge combo
Buckeyefan 1
Buckeyefan 1
Either should go well with the Fluance, but you'll definitely notice a huge dB difference as the Fluance is speced at 88dB, and these center channels are 94 and 96dB. You'll have little trouble hearing "voices" should you avoid lowering the center channel 6dB. You may also notice the horn loaded tweeters are a bit more lively than those in the Fluance set. Your receiver should have plenty of control to mesh the levels to your liking. Good luck with the move.
Blundaar
Hi folks. My first post to this site. Glad to be here!
I'll be picking up my Pioneer 1015TX this Saturday to replace my Sony STR-DB-935 (I believe that's the right #)- it was getting a little long in the tooth. That said, the new toy will be plugged into a pair of KEF Q-75C's w/a Q-100 (front and center), two DCM TF-400's for the rear and a 10" Mirage sub. I'll let you know in a few days!
brian32672
brian32672
Welcome to Audioholics.
Yeah, please post your thoughts on your new setup, once you have it all set to your liking.... Surely someone will have a similar set-up....
msmith855
I've already ordered my 1015 online as well so I should get it in next week to pair up with:
Center: Infinity Beta C360
http://www.infinitysystems.com/homeaudio/product_detail.aspx?prod=BETAC360BK&series=BET&cat=CCS
Front: Infinity Beta 50 (contemplating Bi-amp'ing these since I don't SB speakers)
http://www.infinitysystems.com/homeaudio/product_detail.aspx?cat=CCS&series=BET&prod=BETA50BK&Status=
Sub: Yamaha (forget the model number)
Surround: Acoustic Research (same as the sub)
*** the sub and surround are next on my hit list to upgrade before the end of the year....
I'll let everyone know how they sound sometime late next week.... :D
