All but one of your statemetns are accurate descriptions of theoretical devices but not real-world ones. If you go buy a UPS, especially a good one, you've also just baught a surge supressor and a line conditioner.
Good. Now you can post the manufacturer spec numbers that say that. And specifically point to the number which makes that claim.
You will not because you cannot. Your very first paragraph demonstrates knowledge only from hearsay. The UPS manufacturer does not claim protection from destructive surges. So you ignore the request for spec numbers. Classic junk science.
A latest myth is to rename a surge protector as a line conditioner. Then many wish it does even more. It’s called a line conditioner. Then it must condition line voltage. Word association proves it must be so. Junk science.
He saw business school graduates using plug-in protectors in IBM. Therefore it must be good! Complete nonsense. They are office workers. But that rationalization is how myths get promoted by the naive to the naive.
Why does every telco that must never suffer damage no use them? Because telcos must suffer no damage - including fire. Another problem seen by most fire departments are scary pictures. Due to system limits, I can only provide one:
Triple w dot pennsburgfireco dot com slash fullstory dot php?58339
However experts in a GE office know this does not happen? Who do we believe? That Fire Marshal. Or JerryLove and his office workers?
Direct lightning strikes routinely cause no damage when a human has basic knowledge. Any laymen can learn from a long list of professionals who say this - some were cited earlier. All 911 Centers must suffer direct lightning strikes - and nobody knew the surge even existed. Oh. Did someone post that citation from a professional? Same solution was routine when all phone called were handled by operators – how long ago? Routine is to have a direct lightning strike without damage even to an operator with a headset on. But only those who learned this stuff before posting would know.
What does his 2000 joule protector do? First, it uses only 630 joules and never more than 1300 joules. What is 1300 joules? Well below what internal protection makes irrelevant. What is that 2000 joules protector doing? Take a $3 power strip. Add some ten cent parts. Sell it for $25 or $150. Profit margins are obscene. Then the naive will see it in a Citigroup office. And recommend it. Then when it fails, the naïve will again recommend it.
What does Sun Microsystems define for server rooms? Obviously not plug-in protectors. Sun wants computers protected:
> Section 6.4.7 Lightning Protection:
> Lightning surges cannot be stopped, but they can be diverted. The plans
> For the data center should be thoroughly reviewed to identify any paths
> For surge entry into the data center. Surge arrestors can be designed into
> The system to help mitigate the potential for lightning damage within the
> Data center. These should divert the power of the surge by providing a
> Path to ground for the surge energy.
Same protector can be earthed in any home for about $1 per protected appliance. That is protection even from direct lightning strikes. Only the naive would know nothing can provide that protection – then recommend the APC for tens or 100 times more money. Clearly price proves it works? The naive learn from office workers - not professionals. Then post subjectively the same myths over and over. Let's hear from another professional:
> Well I assert, from personal and broadcast experience spanning 30 years,
> that you can design a system that will handle *direct lightning strikes* on
> a routine basis. It takes some planning and careful layout, but it's not
> hard, nor is it overly expensive. At WXIA-TV, my other job, we take direct
> lightning strikes nearly every time there's a thunderstorm. Our downtime
> from such strikes is almost non-existant. The last time we went down
> from a strike, it was due to a strike on the power company's lines knocking
> *them* out, ...
> Since my disasterous strike, I've been campaigning vigorously to educate
> amateurs that you *can* avoid damage from direct strikes. The belief that
> there's no protection from direct strike damage is *myth*. ...
> The keys to effective lightning protection are surprisingly simple, and
> surprisingly less than obvious. Of course you *must* have a single point
> ground system that eliminates all ground loops. And you must present a
> low *impedance* path for the energy to go. That's most generally a low
> *inductance* path rather than just a low ohm DC path.
Strange. Direct lightning strikes to radio antennas, utility wires connected to all household appliances, church steeples, Sun server rooms, every telco switching center everywhere in the world, and munitions dumps. Every one has no damage even from direct lightning strikes by doing the same thing. And by not spending tens or 100 times more for an APC ... that does not even claim protection from surges.
1300 joules will not even damage appliances. JerryLove should have known that 1300 joules is trivial. But that means first learning numbers before knowing something. So tiny that a surge may even damage the undersized protector. No problem. Damage (no protection) gets the naive to promote more.
Where are those spec numbers? Is even a one line spec that difficult to quote? What is your professional information source? GE office workers? Classic junk science reasoning. But then you even believe all surges are same. And that direct lightning strikes must always cause damage. Amazing how 100 years of science just changed because you know better.
A protector is only as effective as its earth ground. That is not what GM office workers say. Therefore we should believe GM office workers? JerryLove's science proof - office workers know 100 years of proven science is wrong. So he recommends APC products.
Quoted above are professionals. In every case, the protector is only as effective as its earth ground. How curious. Ben Franklin demonstrated the same concept in 1752.
