paradigm great speakers?
grd4spd
grd4spd
due to the design and desired look of the space the only option is in-wall.
i agree that the Paradigm speakers are the best value for the money....fine speaker, great price.
regards,
terry
3db
3db
And thats why I bought the PSB Image series
regards,
terry
cause to my ears, they bested the Paradigm Monitor series for the same or less money . :rolleyes:
grd4spd
grd4spd
in wall?
how and where? please offer more info.........
regards,
terry
gene
gene
Audioholics Master Chief
Administrator
You might also wish to look into similarly priced Axioms. Many Axiom owners and reviewers for that matter swear by their value as well.
grd4spd
grd4spd
thanks for the referal....i did listen to the Axiom....however i prefered the Paradigm. :)
regards,
terry
2
279BLUE
Paradigm in-walls
Grd4spd - I too have decided on the sa-15s for the rear surrounds. Seems like the best fit for my situation as well even if I loose a little over the ADPs. Am going to go w/ studio 60 for the front though. Anyway we do what we can. We can't all have dedicated rooms. PS nice Warmboard. at least you toes will be toasty while you enjoy the sound.
grd4spd
grd4spd
what are you losing?
had my design constraints (dont want big speaks as furniture) not been an issue i would go with S8's....but it not in the design plan.
......having dedicated rooms for sound/theatre as not as big priority as it used to be....i do have three other houses to play with. ;)
thanks!
yeah, that warmboard is nice.....great solution for a wonderful way to heat......nothing like toasty toes apre-ski when its 10degrees out!!
regards,
terry
