• Thread starter hardcore_gamer99
  • Start date
hardcore_gamer99
Like you've already been told:
placement placement placement
and integration
as i dont have space for 2 pb 2000s so i can go with 2 1000 pros and yes i can easily put them diagonally opoosite as well. but not pb 2000 pros
hardcore_gamer99
No. Not below 30-40hz. Above that, maybe.
You might get lucky and smooth the response some. But you can’t just drop two subs and expect it to be magically better. There’s a good chance it could get worse.
then 2 pb 1000 pros
G
Golfx
Look—please pause a moment—reread the posts above.
There is a disconnect between what you are perceiving while reading and what we are saying.
You want to spend money to fix your problem (by buying two new subs) but it is your SETUP.
We instead believe you should have: 1) not sold your old sub, 2) examined your phase setup and/or 3) moved your sub to different locations.
Trell
Trell
And I'll add 4) try different listening positions and placement of speakers.
hardcore_gamer99
subwoofer movement was not possible for pb 2000 pro try to understand its big. I sold it only because of size nothing else. Else i could have added more 2000. If i buy smaller size i can easily pick it up myself. thts the issue
jarablue
Dude, I have a pb 2000 pro in a small room. I mean a really small room.
Is your living quarters the size of a small closet? The pb 2000 pro is not that big and can certainly fit in a small room. Unless you live in a 1x1 room. And again....MID BASS is awesome on the pb 2000 pro. Good luck with whatever you do to fix your pboblem.
hardcore_gamer99
sold pb 2000 pro for now as needed funds. will decide later
W
wspohn
Is anyone else using Hsu VTF-15H Mk 2 subs? I have found them to be quite clean and crisp. VTF - TN1 appear to be the current equivalent model.
