New roof solar system (many questions)
TankTop5
Unfortunately Solar and other Renewables are headed in the wrong direction. It started with the Biden admin and gotten or going to get way worse with Trump. The biggest was local utilities no longer buying your excess at the bulk sell rate.
Couple that with incentives being gutted and it's a huge disappointment.
Helped a buddy put in 16,000 watts for 100%+ dependency and just made it under the wire for production buy back and all possible incentives. He contracted out the panel electrical with auto-disconnect so he doesn't feed back to the grid in an outage and kill a line man.
My advice is size your system to take care of you in it's most productive months given your local and lean on your provider in the lean months.
Here CSU does water, power and gas and you can offset water and gas with solar. Problem is they capped it so no new solar qualifies. Pretty much everywhere is killing solar with regulations, the only places it’s worthwhile in many cases is off grid. Leave it to government to f up a good thing almost every time.
BoredSysAdmin
BoredSysAdmin
So, this is all a fairly steep learning curve. As in all things there is shoddy work and bad advice abounding.
I am going to tell you again straight up, that if you don't have a good south facing roof unobstructed to the sun's rays, then forget it right there.
These East/West facing roof systems will never pay off. I know there a lot done and these marginal systems installed, but they should not be. Ethical companies will not sell you those.
Now, the first thing to understand is the NEC rules. The maximum power that the panels can deliver CAN NOT exceed 20% of the rating of your panel and electrical service. If you want to go higher then you have to instal a higher capacity electrical service, and may well have to pay for the utility to increase their infrastructure also. This makes it not worth it. So kept my original service.
The reason is that if you used the maximum draw your panel is rated at, and the panels are at maximum allowed then your service is actually handling 20% more power than spec. The NEC have granted that much 'wiggle room'. So I have a 200 amp service and so my max solar production can be no higher than 7.5 KW. So I have 20 panels that could max out at 7.6 KW, but that is within the what is allowed, but adding another panel would not be.
They will make you bring your service up to NEC 24, which essentially means SPD 1 surge protection at entry of your service to your home, and SPD-2 at all electrical panels.
Now I advise knowing your local electrical codes, and you will need to pull a building permit. Also contact your electrical service provider for any standards and codes they may enforce. In particular they will have questions about the phase locked loop systems involved to synchronize with their service. I did have trouble making our power company understand how my system achieved this, which surprised me. My first contact was in the pig dribble ignorant category. But once I got to talk to someone with more than one functional neuron and half a synapse, we got on swimmingly, and they were very helpful. The local electrical inspector was good enough to pay me a visit early in my planning stage. He told me he passes very few at the first inspection and two and three inspections is in the realms of the norm for him.
So I had mine installed by Blue Raven solar. After a little initial friction, a very good working relationship developed with their engineers.
Now you do need to stay involved and supervise a robust and neat installation. I stopped mine twice. By the third time they understood it was going to be my way, or the highway.
Now, these systems are actually quite simple. The panels are installed on the roof, and make sure you have a safe design. Also make sure your roof trusses are rated for the extra load. I still have a 100% load factor left after installation, but I went overboard with the truss design, as I wanted Florida hurricane spec.
Now each panel has it own inverter and a phase locked loop. Down below is the combiner, which synchronizes your system to the electrical service, and all the panel inverters synchronize to that.
The there is a fireman's switch so they can shut the system down. Your utility will need to install a meter that keeps track of what you take from them and what you sell back to the utility.
Now in the event of a power cut, the combiner shuts the system down, as they don't want downed lines going live from your system. This is why standby generators must have an automatic transfer switch to disconnect you from your utility in the event of a power cut.
Now make sure you have a really good ground. If it does not meet spec. then you will need a new one. I really went over the top with mine, when I built the house, so it was fine.
Now one important point. The grounding of the system, and especially the panels, must be well done. A big problem has been dissimilar metals causing galvanic corrosion resulting in high resistance grounds and fires over time. So watch out for that.
I did have issue getting the installation really tidy, like specifying pull elbows rather then ugly bent steel. This actually speeded things up, as it makes pulling wires quicker and easier Failure to adhere to this spec of mine, was the cause of one of the stops I called. If you have a good outfit, then they will in the end be happy, One of the senior engineers wrote my a nice eMail to say they are using my photographs in their teachings and instructions now.
I am glad to say we passed both electrical and building inspections first time. The Inspection from Dakota Electric was the most rigorous of all, which is as it should be. A the end they placed their sticker and turned the system on, and it has stayed on since with no issues.
I have no had any buzzes due to this system on my audio systems, except for those Marantz were responsible for.
Now, I am hoping that this system will replace 70% to 75% of our electrical usage. The big user is AC. Our unit while running used 7.5 KW, which is max panel production in a good noonday sun.
Last month we had a bill of $125 as we have had a really humid heat wave. I have been in credit two months and had minimal bills the other months. Last month's bill would have been over $500 without the solar panels. The panels have produced 8.1 megawatt hours of electricity so far this year. I am hoping for around 12 megawatt hours by years end. Last year we consumed 16 megawatt hours. I reckon we should make another 4 megawatt hours.
Their program helps you keep track on your phone, and you can check that all panels are producing, and you would see if a panel had failed right away.
So, that is what I know right now. Unfortunately you have to be careful as inappropriate installations and unrealistic goals abound.
There is a lot here, so I will try to address at least some of it:
a) I do have a South-West (240 degrees) facing roof
b) Not 100% sure what kind of electric service I have, but then I installed my L2 EV Charger 240v/40a - It passed the city electrical inspection and (electrically) is working fine since then.
c)I do inspections for all home changes - so that's not an issue. Our electrical inspector is a reasonable gent, unlike our plumbing inspector, who's a local horror.
d) I spoke with one local solar vendor and most likely decided not to go with him since there were a few problems, like I never got an itemized quote, the estimation charts show higher electrical consumption in January, compared to April - I made no sense since my actual electrical usage I sent to him did not shown this.
e) My roof age is approximately 21 yo. So far, both first and second solar contractors recommend a new roof, but at least the second guy will do a free inspection before making their official recommendations.
d) The 1st estimation was for 23 panels, totaling about 13k kWh per year.
e) The panels are:
HiN-T435NF(BK)
Hyundai Energy Solutions
and inverters:
IQ8AC-72-M-US (240V)
Enphase Energy Inc
f) I have two zone AC system(s) and they are the biggest electrical usage, but my EV is about the second biggest usage.
e) The panels are:
HiN-T435NF(BK)
and inverters:
Enphase Energy Inc
What are the roof shingles? If asphalt then the life is 25 years max. I would absolutely not put solar panels on asphalt shingles 21 years old. That would be a bad mistake.
jinjuku
jinjuku
Moderator
If you are getting the roof replaced you could look at a steel roof with non-penetrating solar panel mounts.
That is the ideal solution, but you have to have the "brass" for it.
dlaloum
The utilities companies in countries where they are privatised, will always try to drop the solar feed in tariff while charging full price for power...
Here in Australia we are getting charged 40c / kwh while receiving 5c / kwh for our feeds into the grid...
Although they have a lengthy pay back time (4+ years) batteries resolve that issue.
Another helpful thing is to design and size your panel layout so you generate at the times that you use - no point generating peak power only to feed it into the grid for pennies...
This is where east/west layouts have an advantage - although your total kwh generated is lower, you are generating power earlier in the morning and later in the afternoon... so what happens is you cover a larger proportion of the household power use from solar.
Adding a battery, and some North facing (in Australia, in the northern hemisphere that would be south facing) and an appropriately sized battery setup should allow most suburban homes to run off their own power for most of the day... at least outside of winter.
Once you have covered household daytime use, and have spare battery capacity, then the best additional alternative is North (south) facing panels, as you want maximum kwh output to charge the battery.
When my north facing panels are still doing nothing in the morning, my east facing ones are powering the morning routine and breakfast....
BoredSysAdmin
BoredSysAdmin
Yeah, I have no intention to put (est) 20 years lasting solar panels on 21 years 21-year-old roof, which is estimated to last around 25 years. But I would rather not guess this stuff or blindly follow internet strangers' advice, but have a few roofing professionals come and take a look and provide quotes. In the end, it's 99.99% I would replace a roof with a new one.
BoredSysAdmin
BoredSysAdmin
Never heard about steer roofs, except in corrugated metal roofs on commercial buildings.
What are the pros and cons of such a roof?
jinjuku
jinjuku
Moderator
It's getting quite popular on residential side now. I would ask your roofing contractor about options and panel compatibility.
Matt34
Matt34
Moderator
Have you seen the new crap CSU is trying to pull, a big FU to anyone that invested in solar:
CSU's proposed changes to net metering
News
As your community-owned, not-for-profit utility, our mission is to deliver safe, reliable and competitively priced energy to all customers. To continue doing so fairly, we are introducing Energy Wise time-of-day rates as our standard electric rate.
Additionally, we are proposing updates to our Net Metering Program that will help ensure our rates reflect the true cost of delivering electricity, especially during peak demand periods. With this proposal, net metering customers will not transition to Energy Wise time-of-day rates, rather they will transition to an Energy Wise Renewable Net Metering Rate Option in January 2027.
Why are we proposing changes?
Not all energy is created equal. On weekdays from 5-9 p.m., electricity demand spikes, and so do the costs to purchase and deliver power. While solar production peaks midday, it drops significantly during these high-demand hours when energy is most expensive.
Currently, Net Metering customers are billed at a flat rate that does not reflect these peak costs. As a result, customers without solar are covering about $600 per year for each net metering customer. This cost shift is not sustainable or fair to the broader customer base.
We value the investment you've made in renewable energy and recognize the importance of solar in our community’s energy future. That’s why we’re proposing new Energy Wise Renewable Energy Net Metering Options, designed to better align costs with usage, while continuing to support solar adoption.
What changes are being proposed?
We understand that changes to Net Metering can impact your long-term investment. Our goal is to be transparent and provide options that reflect the cost of service while maintaining customer choice.
Current rate option:*
Access and Facilities Charge (Per Day), which helps cover fixed costs of maintaining the grid.
Access and Facilities Charge (Per kWh), which reflects energy usage and delivery costs.
Proposed rate option:*
A slight increase to the Access and Facilities Charge (Per Day).
A decrease to the Access and Facilities Charge (Per kWh).
The addition of a Demand Charge (Per kW Per Day), which accounts for energy demand during peak hours.
Based on the highest 15-minute demand recorded during on-peak hours (Monday through Friday, 5 p.m. to 9 p.m.) within the billing period.
*In addition to Electric Cost Adjustment and Electric Capacity Charges
eljr
eljr
Has anyone done it?
What are your suggestions?
Any gottchas, pitfalls, good brands, bad brands (etc)?
Any experience you could share would be welcome.
They are ugly as hell. My town has placed ordinances to stop the blight.
jinjuku
jinjuku
Moderator
News
This is why I personally would size systems to provide their production against the sweet spot. Where I'm at that 8 out of 12 months.
It's not worth chasing because of the 'peak rate' shell game.
Additionally I would design it to expand to 90+% if rates when through the roof.
BoredSysAdmin
BoredSysAdmin
I disagree with you, and I'm thrilled I don't live in your town, but irregardless (c), gaining over $50,000 (NET) over less than 20 years for doing absolutely nothing is a good enough reason all by itself to "suffer" the "insuffabrable blight" of few glass panels on the roof covering these amazing, elegant, and exquisite asphalt shingles.
jinjuku
jinjuku
Moderator
I wish solar was intertwined in our building codes and incentives a bit more. Good luck exploring solar.
I don't think they are particularly ugly. Most visitors have not even noticed the 20 panels on the roof.
I have to say you have lately become our resident bilge merchant.
TankTop5
News
News
Now ask why CSU is spending $600 million on fiber optic to monitor transmission lines.
It’s not as advertised.
