David
I'm really glad to hear that you got the dome version. I was ready to start whining that there's not enough love for good dome tweeters around here. The Dayton RS28F is an excellent tweeter. Very low distortion at lower frequencies.
Of course, it's possible that Meniscus had sold out of the Fountek ribbons and needed to move some domes
It's been a while since heard these two speakers, but I think you remembered correctly what I said. At first listen, both versions sounded pretty similar. The dome version was a bit cleaner sounding in the lower treble range, and the ribbon was a bit cleaner in the upper range. If I remember correctly, the dome crossover point is about 2.2 kHz and the ribbon crossover point is 2.5 kHz.
Dennis tried some other less expensive ribbon and planar tweeters for this design, but they didn't work well at all. The LCY ribbon worked well, but it was nearly $200 each at the time. Also, at that time, there were some supply and QC problems with LCY that since have been ironed out. That was one of the reasons why Salk dropped the LCY for the RAAL tweeter.
Grant's observation about power handling between the Fountek and Dayton tweets is also good.
The reason why the crossovers for the two ER18 MTM versions are so different is because the ribbon tweeter required it. The dome is very robust and can actually be crossed over below 2 kHz. Not the ribbon. Dennis says he was going as low as he dared at about 2.5 kHz. And it required some coaxing.
TLS Guy's description of the the ribbon hi-pass network is very good. It required a resonance or notch filter, the part with the resistor, coil, and cap in series with each other (an LCR filter), but in parallel with the tweeter. This LCR filter, as TLS Guy described, changes the Q of the filter to minimize the broad peak below the crossover point. This changed the shape of the tweeter's roll off curve.
Dennis takes care to make the roll off curves of the woofer and tweeter as symmetrical as possible with each other, so as a result, the woofer circuits have to be different in each version. I believe Grant mentioned this helps ensure good driver phase integration.
Dennis says these speakers have LR 4th order crossover slopes. Some of you may have noticed that the crossover diagrams don't look like 4th order filters. You are correct. Dennis like to make a distinction between the electrical and the acoustic roll off curves. "Electrical" refers to the transfer function of the filter, and "acoustic" refers to the measured sound of the driver combined with the filter.
I've rambled a bit, but I hope this covers your questions. Great conversation
So David, where are the photos?
