Need some help with how to power speakers
N
ngfarr08
also that review must be mistaken because when i recived the package it came with a manual and a warranty, i just called "acoustic audio" and i activated my warranty on my speakers which they recognized, i have two year warranty from the manufacturer so that person must have been mistaken
markw
They may guarantee it will survive the power, but they don't guarantee they will sound good. That issue pops up here more often than you can imagine.
Davemcc
Davemcc
Go to a pawn shop and pick out a $20 receiver that still works. For party music, it doesn't matter how old the receiver is. Plug those two speakers into the pawn shop receiver and be done with it. Don't try to run the junk speakers off your good system.
hello-
so i need some advice with a pretty strange set up,i recently purchased two 500 watt speakers to add to my stereo, they are very low quality and sound pretty bad when the bass level is even a reasonable level, but that is what i was looking for a cheap speaker.
my current stereo consists of 4 125 watt speakers and a 500 watt receiver along with a powered 150 watt sub. this works perfectly obviously and all of the components are high quality and sound very goo when the bass and treble levels are set one way.
i originally thought when i bought these new 500 watt speakers i would just add an amplifier and i would be fine, but now i have learned these new speakers sound awful when the bass and treble levels are at the level i keep my other speakers. so now i must find a system in which i can separately control the bass and treble levels of these new speakers alone, as well as power them, my first thought was an amplifier with such controls which i have been un able to find, then i thought an entire new receiver but that seems slightly stupid. i could use some advice if anyone knows of a product out that i could use with an amp to adjust the levels, or an amp that also has controls on them.
thank you for any help you all can give.
There are good speakers that are cheap and bad ones. They'll sound the way they sound. Buying new electronics won't give you what you want. Good speakers will sound good, even when connected to OK electronics. Bad speakers will sound bad on the best electronics and there's nothing you can do to change this fact. You can EQ the crap out of the system and all that will happen is the speakers will meet their end sooner than you expected.
Sell the new speakers, learn from the experience and buy the best speakers you can afford. Build some from a kit if you can, or look around here for recommendations. They don't need to be big, or expensive but they do need to be designed correctly in order to sound good.
Another thing that absolutely needs to be remembered- everyone's hearing is somewhat different and that's why so many different speaker brands exist. Some similarities will exist between them but there can also be a vast difference in sound. A friend of mine tested a pair of Denmark speakers, which were owned by someone he works with. Bass was OK, highs were OK but the midrange was basically absent. The problem with this is that human hearing is most sensitive in the range that wasn't there. That's where most of the sound we need to hear lives and if it's going to sound real, it has to be reproduced accurately. Any woofer can be put into a box but there's no guarantee that it will sound good. All speakers have physical characteristics that dictate what box will work for bass response and bypassing this guarantees one thing- it's going to sound bad unless the person who built them either tried a lot of different ones or they just got lucky. In the absence of skill and knowledge, luck will do as long as the results are good.
Lordoftherings
Lordoftherings
+1 Yaaaaa... :):):):)
