MacManNM said:
Box size, internal dimensions 25”h X 15”w X 10”d
I recommend using an electronic crossover, not a passive unit in the sub, with a sharp 24db/oct roll-off, sending something like 70 and down to the sub, with 70 and up going to your loudspeakers. Are you not going to use your SVS units? If so, you are going to need to do a little more work.
.....Mac, first, is the shape of the box you detailed important?....5 parts high, by three parts wide, by two parts deep?....I mean, is that "specific" shape important for the range of 50-150?....those internal measurement numbers of 25x15x10 also give in internal volume of 2.173 cubic feet....the soundstream website said .6 to .8 cubic feet for suggested variables of the internal volume for the Van Gogh 12 inch element as per sealed box....yeah, I'm thinking 12 now, Brian....
.....I also designate crossovers as passive and active....passive to me says the source signal or the pre-amped millivolt signals pass through the crossover, i.e. electronic crossovers.....active to me says amplified watts are going through the crossover, i.e. internally mounted crossovers and L-pads....back to the drawing board.....
.....Buck, I want to stay with sealed boxes....I gots the power to shove them....
.....WmAx, if I need to cut the bottom of the full-range signal to the mains and rears, I can do so from the satellite outputs of the Paradigm unit at 50, 80, or 120, but the mains and rears are two-way, which says the low end squats to pee, and I probably won't need to cut the bottom of the mains regiment....this is getting interesting.....
.....edit....oops, was dividing by 1726 instead of 1728....internal measurements of 25x15x10=3750 cubic inches divided by 1728 cubic inches in a cubic foot=2.17 cubic footses....the Soundstream site says the 12 inch element I am most interested in needs an internal volume of .6 to .8 cubic feet....here's a question....does the internal volume suggested discount the part of the element occupying the internal volume?....I mean the cone and magnet structure of the element inside the internal volume?.....we're after the truth and to learn here, guys.....
