Need help wall mounting speakers
Danzilla31
Dims for your surrounds are 7 3/4" x 19 1/2" x 12 1/2" per the manual. I'd think the Pinpoint AM40 (and there are some Videosecu brand mounts that are essentially the same) is another mounting option for you since they can accomodate up to 50 lbs and the depth/width are within its parameters. I paid a lot less than $90 each for mine...more like in the $35 range IIRC so shop around. They have some positioning options, altho a tv mount may have more....
Hey thanks for the heads up I will for sure check those out. I cant get started till this weekend after work and it sure helps to have options to shop around! Once I figure out a way to get them up there I will for sure post some pics to show you guys how it turned out.
snakeeyes
If you get it you gotta let me know how it sounds!
Ya I am probably going to snag the cheaper Outlaw 5000 so I can buy other stuff sooner. Building up 3 systems so it’s getting expensive. HT room movie focused 5.1, bedroom music focused 2.1, and budget living room 5.1.
Danzilla31
Oh yeeeaahh now we're talking I like it! man I wish I had a room for a dedicated home theater! Might just have to crack a few beers with ya in your new movie room when its all finished! Lol
snakeeyes
It’s more of a man cave bonus room but it’s got a half bath and it’s not bad. it’s got a ways to go. I have some new flooring to put down in the entire house this fall. :)
K
KenM10759
Sounds similar to my situation.
Living room 5.1.2 system (almost there) for "general purpose" music and movies. Office 2.1 system for music. Guest bedroom 5.1 system also for general purpose movies and music, my budget system.
The last one is the most recent and just about done, just rehabilitating an old sub with a new driver and amp for a shade under $300. Total system expense will top out at $750. Living room system almost done, just need the AM230 module in my NAD T758 receiver to have the Atmos-enabled speakers (KEF R50) connected. I don't even want to do the exact numbers on what I have into that system, it's now approaching $7k. Office system complete, but easily the sweetest-sounding one of the 3 but for speakers, amp/streamer and sub it was $2150.
And none of this is ever considered permanent. There will always be components that fail, become obsolete, or just need upgrading. Like my machinist trade/hobby or my motorcycle passion, the equipment list is endless...and expensive.
I see 4 screws above the binding post. Looks like mounting screws to me. Perhaps you can modify a wall mount bracket to accommodate a mounting plate attached to the screw holes so you don't really need to drill into the box itself in case you want to sell it or a different use.
Danzilla31
Those are mounting screws good catch. I was thinking of drilling into the mount plates of the tv mounts new holes to mount to the speaker directly or using these wood blocks I made drilling holes through there then mounting the tv mount directly into the wood block I think those are my 2 best options.
K
KenM10759
Are you certain that they're mounting screws and not holding a crossover network inside to the speaker's back wall?
Danzilla31
Yeah I'm certain in the owners manual they state that these speakers can be mounted to the omnimount 30's. They no longer make those mounts but those are the threads and screws for those mounts.
snakeeyes
It must be crazy waiting for your new subs. Did you sell the old ones?
Danzilla31
Bro I am losing MY MIND! Yep those subs just walked out the door today! A nice contribution to the Rhythmik fund! :D It was cool to listen to my system without them. It's neat to hear what comes from the subs and what's coming from the rest. One thing I learned from doing it is those surrounds are friggin awesome and worth all the effort I'm going through to place them on the wall.
snakeeyes
First week of September is very soon. You are almost there :)
Danzilla31
Ok fellas I've got the mounts on the speakers I measured and made holes for the four threaded screws that go into the speakers. Those go all through the wood and lock into the speakers. Then above them I have the mounting post for the speakers mounts I used 8 3/4 inch screws in each that go through the wood but not into the speaker just to be safe. Those mounts can hold 40lbs so I'm confident these babies are going nowhere. Tommorow morning a good friend of mine is helping me with the wall mounts the speakers attach to. Once we get them all mounted I'll shoot you guys some pics show you how it's turned out. Thanks for all your help guys and the summon my inner MacGyver pep talk one of ya gave me? Couldn't of done it without ya man couldn't of done it without ya!
Good job. A final thought: if the speaker back has a nice finish, may want to apply a smooth piece of material between the speaker and that wood plate to reduce rubbing, marks just in case.
Drunkpenguin
Looks good! Make sure you hit studs when you mount them. Macgyver could do it on the first try without a stud finder! :D
Danzilla31
Okay guys it's done!!!! Thanks for all your help I couldn't have done it without some great input. There were some snags but it looks awesome! I've got long enough wires I'm gonna hook it up tonight calibrate and see how it sounds. Here's some pics!
