highfihoney
your right about set amp'smtrycrafts said:You may be misunderstanding what is posted here about amps as I bet you will not see a post that claims ALL amps perform the same. That is a challenge for you to find that post. One only has to look at SETs![]()
Reading between the lines is dangerous at times.![]()
i do agree that when using amplifiers of like specification's & with all level's matched that it would be extremely hard if not impossible in a dbt to tell the difference between the different amp's but that is a very dangerous test to base a purchasing decision on if performance is an issue,there isnt very many gear owners who do not drive their gear to its limits even though they may not know it especially when using the amps for home theater.
here is what i mainly disagree with,when you post in threads that all amps sound the same it gives newbee's the impression that sounding the same & performing the same are one in the same which they are not.
most specs are based on dummy loads which do not apply to real world demands & some manufacturers chose to either over rate their gear or even under rate their gear,this thread is an excellent case in point with the klipschorns,you can read the specs for a week & still not know how overly built & under rated the speakers are,the specs also do not tell the truth when it comes to real world power handeling.
being that khorns are extremely under rated/over built & that recomendations for amplification have been given by some people based soley on specs in my oponion the advice given is bad advice,this is where first hand knowledge comes into play, without first hand knowledge of what a khorn is capable of there is no way to get them to perform to their maximum capability by reading the specs supplied from klipsch.
