The truth on the Behringer A500 amp is that it's not all people have talked it up to be. That amp will unlikely put out 100 watts into two channels at .05% thd. When you have speakers that can handle, say 250 watts rms, this Behringer is not the best amp for the application. My Denon 3805 puts out very similar power.
That's not saying the A500 is any slouch, but it's no more than a quality A/V receiver. Without knowing the capacitor size, transformer, or heat sink, and knowing the A500 has a weight of 18lbs, it's my opinion that amp is worth every bit of $180, but not a penny more. It's a great addition to an A/V receiver to biamp a set of mains that need a little more juice in the low end, but to recommend it for a set of Khorns is probably going a bit too far.
Denon 3805 specs into 1kHz and .07% thd:
http://usa.denon.com/AVR3805_DFU_ownersmanual.pdf
A500 specs:
Specifications: *Output power (1 kHz, 0.1% THD)** per channel stereo: 160 watts RMS @ 8 ohms, 230 watts RMS @ 4 ohms. *Output power (1 kHz, 0.1% THD) bridged mono: 500 watts RMS @ 8 ohms. *Weight: 18.5 lbs.
** now imagine what the ratings would be, taken at 20-20,000Hz and .05% THD. Check the difference in wattage on the Denon 3805 to get an idea.
I'd much rather see someone invest another $120 and get the Behringer EP2500 Europower amp with the Khorns. It matches up better with peak rms output handling.
