need 2nd subwoofer added to samsung q990d soundbar
  • Thread starter Thread starter marcus oakley
marcus oakley
146
0
16
55
England
hi
can you tell me if have been told that you can modify your Samsung q990d sound system
I want to use the normal q990d subwoofer plus you can add a additional 2nd subwoofer
from a different brand
utube shows a guy using a klipsch subwoofer with the system
or a svs sub either a svs pb2000 or a svs pb3000
with the samsung q990d subwoofer as well
can this definitely work
if so can you please so kindly put me in touch with a samsung technical expert who can modify my samsung q990d for me so I can use two subwoofers instead of the normal just q990d sub
need your help and technical support
or can you please so kindly tell me any contact number on who can modify the system for me
it would help me out greatly
if I can get more low end bass from my system
and why don't samsung create the next soundbar with 2 subwoofer outputs
need your expertise asap thanks kindly from marcus I'm from the uk postcode nn8 2jr
@marcus oakley The subwoofer connects to the soundbar wirelessly through bluetooth. There is no simple way to add another subwoofer. These integrated systems are meant to be used standalone. The only person modifying these systems is some Youtuber looking for clicks on his channel.
Kingnoob and marcus oakley a pair made in social network hell
if op wants a better sub why did they get the bar? It’s no secret the subs size. Or upgrade to something else make a new thread somewhere else.
:confused:Maybe they should call Samsung this would be a funny call.
