need 2nd subwoofer added to samsung q990d soundbar
  • Thread starter Thread starter marcus oakley
marcus oakley
hi
can you tell me if have been told that you can modify your Samsung q990d sound system
I want to use the normal q990d subwoofer plus you can add a additional 2nd subwoofer
from a different brand
utube shows a guy using a klipsch subwoofer with the system
or a svs sub either a svs pb2000 or a svs pb3000
with the samsung q990d subwoofer as well
can this definitely work
if so can you please so kindly put me in touch with a samsung technical expert who can modify my samsung q990d for me so I can use two subwoofers instead of the normal just q990d sub
need your help and technical support
or can you please so kindly tell me any contact number on who can modify the system for me
it would help me out greatly
if I can get more low end bass from my system
and why don't samsung create the next soundbar with 2 subwoofer outputs
need your expertise asap thanks kindly from marcus I'm from the uk postcode nn8 2jr
hi
That system needs a lot more help than deep bass. The sub connection is by Wi-Fi and I don't see any way to connect a powered subwoofer designed to connect to a sub pre-out.
I have to say that if you want improved sound then that system needs to be up for sale on eBay fast. I highly doubt that system would even go low enough to connect to a decent system.
If you want to improve your sound then you need a receiver and at least decent right and left speakers, plus sub and build your system up from there.
The other thing is you don't want to use a decent sub with a lesser sub.
