audiohonic65
One point to sonsider here is that wood is cheaper and easier to work with as compared to metal. Also, MDF is engineered to be effectively flat on it's surfaces. Plyw is genearlly not flat. Last, MDF machines are very nice and gives a uniform look.
lsiberian
lsiberian
The ply I've used is flat enough for speaker building. The key to good machining is having good bits and blades. Whiteside or Lee Valley bits have been shown to work great with mdf and ply. The Forrest blade looks very nice. Once the rain stop I plan to give it a try.
Give it a coat of paste wax before you use it- the wood resin (in actual lumber) will have a harder time sticking to it.
Alex2507
Alex2507
Now you tell me. :rolleyes:
Actually I knew that but I forgot which reminds me of the saying 'I forgot more than you'll ever know" but I was milling up some 100+ year old Southern Yellow Pine to use as speaker bracing and the sap had to be cleaned off the blade repeatedly.
Wax on DIYers! :)
lsiberian
lsiberian
I've never waxed a saw blade before. :eek:
I had no idea
Chopper Greg
Chopper Greg
I went to the local lumber yard, and the only MDF they had was 1/2" for 4x8 sheets or 3/4" shelving material.
OTOH, as far as 3/4" ply, all they had was the type made with thicker verniers - perhaps 7 layers, is this stuff ok?
lsiberian
lsiberian
For subs it would probably be fine, but for loudspeaker enclosures you want 13 ply. Home depot does carry 13 ply.
sawzalot
sawzalot
What is the reason behind wanting more layers?
Strength , multiple layers laminated together with the grains running at 90 degrees to the layer before it amounts to the strongest design possible, also these multi layered products will stay true and straight better than a solid and or minimal layered product. Most multi ply 13 or more, would be used in custom cabinet making , where strength and durability are a must.
Wax on DIYers! :)
How do you like those yellow pine splinters? Kinda burns, eh? I used Southern Yellow Pine for the baffles in the first speaker cabinets I ever made.
Try citrus-based cleaner for saw blades.
Cabinet grade plywood doesn't have voids in it like regular plywood, which makes it usable with exposed edges like drawer boxes and dividers. The layers are always laid perpendicular to each other and that adds a lot of stiffness, too.
Home Depot and Lowes carry 13 layer but after the experiences I have had with plywood from big box stores, I won't buy it from them again. If you go to a woodworking store like Rockler or WoodCraft, they can tell you where to get the best lumber and sheet goods.
One thing about cabinet grade plywood- its dimensions are usually metric. 3/4" is usually called 19mm.
Chopper Greg
Chopper Greg
I was thing about ordering marine ply ( and it can be obtained in 4x10 and 4x12 sheets if you want it that big ) - it too has to be void free, and uses a waterproof adhesive - not water resistant adhesive that exterior grade uses.
sawzalot
sawzalot
Why? are you putting these subs on your boat? J/K of course but really there is no logical reason to use that ply unless it is more readily available or free, as I know it costs quite a bit more than Birch or MDF.
lsiberian
lsiberian
What if he's flooding prone. It would save him from diving into the rising waters to save his precious subwoofer. :D
Chopper Greg
Chopper Greg
After having dropped by a couple of cabinet shops, it ends up costing about the same per sq/ft - the local shops appear to be very reluctant to part with some of theirs.
lsiberian
lsiberian
I know it's sinful to suggest using the big box stuff, but with some bondo I think it would be just fine for a sub. In fact my Home Depot bondo's pieces before putting them up for sell.
No point in you paying an arm and a leg. I've used 5-ply and gotten decent results before. Folks here talk in ideals. But life is about compromise.
WmAx
WmAx
Standard cabinet grade hard wood ply is sufficient for subwoofer boxes, and still superior to MDF. You do not need 13 ply for subwoofers.
-Chris
What kind of glue will you be using? Wood glue won't work because it's water-based.
