Marantz AV 10 installed: - Early Review and Impressions.
It is because I suspect that those 7705 and 7706 pre/pros had a lot of commonality with the AVRs on which they were based. I can't be certain, but that is the only explanation I can come up with. My 7705 was my first introduction to Atmos, and the 7706 is similar. The AV 10 is a totally new design and has nothing in common with any AVR. It also ways 37 lb and in its rack mount about 50 lb and a real challenge to mount in a 19" rack. However, I did a safe robust installation that also is good cosmetically. The point is that if it contained any power amps it would have been so heavy you would not get it mounted. So if takes a 37 lb lump to make a decent well made Atmos pre/pro, then a receiver would be next to impossible and actually be a non starter. All I can tell you is that the Atmos performance of this unit is a total revelation and not just better by an incremental amount, but a massive revelation of what this technology can do. This came as a total surprise to me, and was immediately obvious, the improvement was colossal. The performance was what I believed Dolby labs expected and published. So as I say, this unit gives a performance with what Dolby '"say on the tin" as they say.
As time passes the more it becomes apparent to me that any type of receiver is a bad idea. It reinforces what Peter Walker always taught me that high gain preamp circuits do not belong in the same space as power amps sharing power supplies. He never wavered about that and never produced an integrated amp, let alone a receiver. He is widely recognized as one of the great giants in the history of audio.
I think you're reaching. Like your hearing at your age....
Just what are your sources in Atmos? Bluray primarily?
I have two sources, BD discs and the Atmos streams from the Berlin Philharmonic Digital Concert Hall. They have a pretty significant archive of concerts in Dolby Atmos. This later is my largest source of Atmos material. On the AV 10 those streams are stunning. I do have a number of well produced Atmos Blu Ray discs.
My nephew Dr. John Apps visited this last weekend. He is also a competent violinist and has performed in non professional orchestras. He wanted to hear the BPO stream of the Mahler Symphony No. 2, the Resurrection Symphony. He was stunned by the realism. This has a large orchestra, soloist and choir and also off stage ensembles. On this rig with the AV 10 it was incredible including the realism of the high up off stage brass ensembles. It has taken this new preamp to convince me of the effectiveness of the Dolby Atmos system. Previously I had considered the benefit marginal. I was wrong again, and this rig has now set me strate. The big problem is putting it together is a massive expense and to do it justice I suspect it does take a dedicated space like this one. So unfortunately the whole thing comes up against the buffers of practicality for widespread application. I think cinemas will have customers for years to come.
So mixed in Atmos or just an algorithm applied to basic 2ch material?
isolar8001
isolar8001
I think that pretty well explains it...the AV10 isn't following Dolbys dianorm for your DD+ Atmos streams, which is where it's usually always enforced.
Very few discs with TrueHD/Atmos have dianorm.
I run into this all the time when I "aquire" streaming tv shows with Atmos...I've even just recoded the audio to remove Atmos more than once. I don't like having to crank the volume up 10 notches just to hear something !
Trebdp83
One can check system information to see just what the hell is going on. One can also post a pic of that information for the benefit of all.;)
dlaloum
It Simultaneously reduces the bass while increasing the treble or vice versa... it "tilts" the frequency response - as per the Quad 34 manual:
As an aside... it is now very much "in vogue" to apply "Harman" target curves, to both boost the bass and provide a tilt down to the treble....
With a tilt control set to +3/-3 Quad was effectively providing the "Harman target" in 1985...
Trell
Trell
You seem to always know the reason for anything concerning AVPs and AVRs without ever offering up actual evidence to back up your claims.
I believe you when you say you believe you have improved sound with the AV 10. The reasons why are many and still unknown.
You have offered up nothing more than your belief that there is a significant difference between. You wouldn’t accept as much from another making such claims without proof on paper.
I’m glad you are enjoying the system and believe you could improve on it still with some tweaks after learning more about its features and capabilities. That goes for the TV as well.;)
Indeed.
Trell
Trell
If you are happy with your unit and the way it is dialed in, good on you. But, just remember your ridiculous amount of posts prior to your 7705 and 7706 failing. It was all about your speakers and the level of perfection you had reached before your AVPs each took a s#%t.
You had no complaints until those units started making noise and had no bad things to say about the BPO Dolby Atmos presentation or the Dolby Surround up mixer. Dolby and Denon/Marantz have simply improved on their products.
Enjoy your system however you have it set up. I’m not convinced you ever had the 7705 or 7706 setup properly and no display of input signals, sound modes or speaker configuration has ever been put on display in any of your posts.
In the future, spare us the first impressions of any new TV you may purchase when your current one finally takes a s#%t. LG has improved on their product as well.;)
The BPO and Microsoft do need to get Dolby Atmos going on Windows for sure. After not too many years, some apps have their support discontinued on older TVs. Even if not discontinued, many apps may not receive updates.
I recall those posts as well and here we are in this thread of his.
isolar8001
isolar8001
There is always room for disagreement, but the post stream is looking like a ‘pile on flame war’ of the OP. Is this necessary?
If you disagree with the OP and expect evidence and science to back up his anecdotal claims, you should be expected to offer your own evidence and science for your disagreement.
Try to remember this is just a hobby. This is thread about a piece of audio/video electronic equipment. It’s not like it will affect our eternity.
True.
We all have our perceptions that maybe can be proved, and most likely can not.
Here's my favorite audio perception I certainly cant prove...but I believe it.
All my music listening is done from file.
Usually flac or m4a...lossless. It sounds good, of course.
Sometimes for fun, I will take files into AudioMuxer and make an mkv video out of the album at hand.
Or just mux them into an mka file.
To me...the same files/album somehow sounds better that way.
It makes no sense, I know...but I believe it !
Trell
Trell
That's not how it works, except in the audiofool world: The one making the claim should back it up.
In this case the OP is very knowledgeable and has both the means (equipment) and the competence to measure the output from the preouts. That includes any noise as well, of course.
You're new here so likely you've missed much history of previous claims and opinions. ;)
Trell
Trell
True.
I believe that you believe that! :D
Trell
Trell
What I said IS how it works in the real world. It’s called ‘peer review’. If you can, do some real peer review. The OP is not beholden to you for anything. Make your own claims.
No it's not how it works in the "real world" and then you go on talking about "real peer review" showing that you don't know what it means or why it's done. Assuming you talk about peer review as done by reputable scientific journals.
I don’t need history to read the current tone of the thread. No one has to 'prove' anything to you. What you are convinced of is your own business.
And then you miss out why there is push back to OP's statements. Had it been anyone else he would have been down on them quite quickly, often quite abrasive.
Go read this post again:
Trebdp83
It is getting a little thick in here, isn’t it? Can somebody open a window? Somebody enjoying their new AVP is hardly a reason for others to lose their minds.
Those familiar with @TLS Guy know what to expect when he posts about one thing or another. It can be equal parts amusing and obnoxious. But, that goes for many around this joint.;)
I’m sure he is pleasantly surprised by the improvement in performance he claims to have experienced with the AV 10. It is no small thing for him to rave about new tech. Some are interested in knowing more about these improvements and how the system is configured. They’ll just have to wait for their own invitation to his home to check it all out.
Squishman
Squishman
There are albums that need to be heard in its entirety. "Dusty in Memphis" is one. McCartney's Ram is another. But I'll be bringing the Dusty Springfield half-speed master LP next weekend. Cannot wait to hear it on the good doctor's system.
Before I retired I was an audio expert. Now, I'm just a student of psychoacoustics.
So as an audio expert did you feel that all amps and preamps sound differently especially if one has higher SINAD than another? :D
No argument EITHER way. No proofs asked. Just curious. :D
We already know TLG Guy, another audio expert, who hates AVR, thinks all speakers and subs should have built-in amps/DSP/electronics.
…this is just a hobby. This is thread about a piece of audio/video electronic equipment. It’s not like it will affect our eternity.
I’ve said that many times, but something like, “Audio is just a hobby, not rocket science or brain/heart surgery”. :D
Definitely not worth it to me to have angry arguments over. :D
