Looking for a 2.1 system to get started. Please help with some basics.
I
ILLLH
Hello, thanks for having me on the forums.
I'm looking to spend roughly $500 on a new home audio system. Eventually I'll get to 5.1, but for now, I'd like to get a solid 2.1 system going.
I was planning on getting a Yamaha RX-V377-R receiver. Any reason why I shouldn't? It's the best-selling on Amazon and I've heard good things about Yamaha. Are there any significant impairments I should be aware of?
That will leave me with about $340 to spend on front speakers and a sub. I was leaning towards the Polk RTi4 for fronts, but I've read Yamaha paired with Polks make a very bright sound. Are the RTi4 a solid choice or should I look elsewhere? What $200~ speakers would you recommend instead? I'll also occasionally listen to music through this system. I do like bass-heavy stuff, but of course would like to avoid a boomy-sounding home theater.
Thanks so much!
BoredSysAdmin
BoredSysAdmin
Wave Crest hvl1 and Dayton sub1200. Both vastly better than Polk
rojo
rojo
Thanks so much!
This is going to be a system you'll live with for quite a while. It's good that you have an eye on starting with a 2.1 channel system and building on it piece by piece. I suggest going one step further and holding off on the sub right now. If you skimp on the subwoofer, you'll be doing yourself a disservice. For now, shop for a receiver + stereo speakers.
For the main LR speakers, I second BSA's suggestion of the WaveCrest Audio HVL-1. Hold off on the sub for now until you can afford something more worthwhile -- say, the NXG NX-BAS-500 for example. Or if you have a large room to pressurize, you might need something more in the $500 - $1000 range (Hsu Research, Outlaw Audio, Rythmik, Powersound Audio, or Reaction Audio), or maybe even a DIY project with a decent amp.
If you do forego the sub for now, the WaveCrest bookshelfs will give you around 55Hz with room gain I think. If you want something that'll play a little deeper, then maybe the Affordable Accuracy towers. It'll all be a moot point once you do get a sub, though; as whatever mains you choose will probably eventually be crossed over with an 80Hz high pass filter.
The Yamaha receiver you picked out is nothing to write home about, but I reckon it'll be reliable if nothing else. This cat seems to know what's up regarding that receiver's YPAO room correction. If you'd like some alternatives to consider, Denon, Marantz, and Pioneer are also worthwhile. Shop for refurbs at Accessories4Less. Onkyo can often give you more features for the buck, but you're also more likely to have to mail it off for warranty repair.
If you wouldn't mind saying where you live, maybe we could help you find a Craigslist deal?
zieglj01
zieglj01
Yamaha WILL Not make speakers sound brighter.
The Sony Core speakers are my preference over the Polk RTi4 speakers.
The Sony is on sale - and they are nice.
http://www.amazon.com/Sony-SSCS5-3-Driver-Bookshelf-Speaker/dp/B00O8YLMVA/ref=sr_1_1?ie=UTF8&qid=1432747669&sr=8-1&keywords=sony+core+speakers
The Polk is somewhat boomy and lacking in overall definition.
For your budget the Wave Crest, Philharmonic AA or the Sony would be
the nice options to look at.
Bookshelf speakers do benefit from a decent subwoofer - if I were to pick
a sub under $500 - it would be the HSU STF-2
http://www.hsuresearch.com/products/stf-2.html
shadyJ
Speaker of the House
Staff member
I would just get a pair of active monitor at $500. I would get either the JBL LSR308 or the Mackie MR8 mk3. For sheer sound quality they will beat any AVR based system you can get for the same price.
its phillip
its phillip
The JBLs are buy 1 get 1 50% off, which comes out to $375 for the pair. Pretty nice :)
agarwalro
agarwalro
I would say go 2.0 with the Philharmonic AA towers. No point getting a weak link sub. Next add the matching center from Philharmonic and a good sub (in the $500-ish range by itself). Last, the side speakers. These could be the regular Pioneer BS-22 and not necessarily the Philharmonic ones.
I
ILLLH
Thanks for all the suggestions! I skipped out on the Polk RTi4 and went with the Wavecrest HVL-1. After adding a sub, I think I'll have a modestly impressive 2.1 for casual movie-watching and music-listening.
zieglj01
zieglj01
Enjoy the adventure!
agarwalro
agarwalro
You just took the first step in becoming an Audioholic, haha! Enjoy the purchase and be sure to check back for set up and optimization articles.
