Left speaker output not working on Yamaha receiver
sakete
I have a Yamaha A2070 receiver and as of this morning the left front speaker output is not working (I'm only using two speakers in a stereo setup connected to this receiver currently). These are passive speakers so I'm using the receiver's amps
Things I've already tried:
- Plugged left speaker wire into right speaker terminal on receiver and the speaker plays fine then, so it's not a problem with the speaker or speaker wire
- Played through different sources and still only hear the right speaker playing
- Unplugged the power cord to receiver, and replugged, no change
- Tried pure direct, no change
- Went through speaker settings in receiver and both speakers appear to be setup correctly
Any suggestions? It's a refurbished receiver from A4L and it should still be under warranty.
Thanks.
Thanks.
Did you mean both channels played the test tone?
If so, the amp is probably fine and it may be a connection issue related to the source.
sakete
No, test tone only plays on right speaker.
What I meant was that in the setup screen I didn't appear to have the left speaker disabled somehow. It's all showing as active, but no test tone.
I'm starting to worry that it's broken...
snakeeyes
Thanks.
Hmm. There’s an advanced menu. In there you can initialize to default settings. I’m not sure if that is the same as a factory reset or not.
Gryph
Gryph
Sounds like you tested what you could to rule out the outboard stuff so it’s probably time to contact AC4L about warranty.
I know it doesn't help at all, but just wanted to emphasize that I would never buy a Refurbished AVR or AVP.
If a hard reset doesn't work, then there is probably a malfunction.
sakete
Right, I just googled it and reset it, still only get right speaker playing. Looks like it's broken.
Ugh :(
Ugh :(
Somewhat the risk of a refurb....but if you're within your 30 days contact A4L. I got two bad refurbs of my last avr, decided to go new for $100 more after that....had patience for two but not three.
PS you're sure the reset was as per your manual? Not just brand?
sakete
I followed instructions I saw online for the brand. It seemed to work though, as all my own settings had disappeared.
I bought this back in August so I'll have to deal with Yamaha. Stuck with refurb now unfortunately.
Oops posted the remote control reset, don't see the other...yet.
ps Not finding it in the manual particularly. There was a suggestion in the troubleshooting section of pressing main for 10 seconds for a reboot and if that didn't work then try a soft reset.....usually the suggestion is the other way around.
Yes that would be considered what people often referred to as factory reset.
sakete
Yamaha will send me a shipping label, at least their support is good. Don't have to pay for shipping myself.
Wow. Yamaha will pay for Shipping both ways under warranty?
With Denon/Marantz, you have to pay for shipping each time. So if you sent them an AVR and they said they fixed it, but it's not really fixed because smoke comes out of it and nothing really works, and you want them to fix it AGAIN, then you will have to pay for shipping AGAIN.
But Yamaha will pay for shipping?
Yamaha rules! :D
Hopefully Yamaha repair support is also much better than Panurgy.
