Ah, I’m just going to replace the whole pot. I got the sub for cheap and I can get even more money back since it’s not functioning correctly. Sent from my iPhone using Tapatalk Your problem is that you do not know it is the pot. You need to carry out the simple sequence of tests I outlined. When you do replace the pot it is not just the resistance you need to worry about, but the taper as well. Pots come in linear and log taper. Volume pots like that are usually log taper.
