Audiophile grade outlet: $255.00 each
Furutech GTX-D (R) NCF Duplex Receptacle is the ultimate AC receptacle
www.thecableco.com
Of course, you will need at least one of these for your more sensitive electrical devices: $1650.00 ea
In addition to 30mm Air Craft Grade Aluminum-alloy, 10mm copper layer and 20mm layer of special alloy-powder were combined to make 3 stratums construction which can eliminate a noise in every frequency rangeWe realized a super clean power supply by succee
www.thecableco.com
Dedicated in wall electrical wiring that is
BETTER than Romex: $500 per 10meters
GigaWatt LC-Y EVO 3X4 is a shielded in-wall cable designed to power high-performance audio and video systems, as well as professional recording and mastering studios. If you have a project coming up where you can replace the basic Romex in your walls with a much higher quality choice, GigaWatt...
jaguaraudiodesign.com
Equi Tech 10WQ Sub Panel: $17965.00
Equitech Model 10WQ 100 amp balanced power systemEquitech Model 10WQ Studio Wall Mount System
www.proaudiosolutions.com
Audiophile Grade Power Pole: ~$3000-8000
Building in rural areas offers several challenges. The lack of basic support services such as water, sewer, and electricity must be addressed before actual construction can begin on the home.
upgradedhome.com
SITTING DOWN AND JUST ENJOYING YOUR RIG:
PRICELESS!!!
