I have done about 50-75% of the mods on my Infinity Primus Towers. Some of the guys on this thread likely haven't been around AH long enough to know what I refer to. But, I did the magnetic shield caulking and the peal-and-seal additions. I haven't done any of the extra bracing, etc (yet, maybe eventually).
But, I don't take my speakers apart just to have a look-see. If I'm taking something apart, it is for repairs or mods only. I have no problems voiding warranties
I note that there seems to be open slots on those crossover boards for components. I would guess that they use the same boards for the towers too, and maybe even for the Prime line too. That is a very wise manufacturing decision: Only produce 1 model of universal crossover board, that will help to drive the cost of manufacturing down and eliminate the possibility of getting the wrong board. Then, you simply populate the components needed for the particular speaker, maybe need a jumper here and there.
