snakeeyes
Yes dual subs if setup correctly will smooth the bass in the room and get rid of the localization issue. However, sub placement is hit or miss without measuring with a mic such as with REW software. You typically will end up with at least one sub at the front of the room. The other might be in the side or back of the room or also in the front of the room. It’s hard to predict.
The size of sub is the other factor. Two tiny subs might not be enough to really work in a particular room. What sub model is it? How big is the room?
