I need my sub back!!??
Mr. Bojankns
I have a klh 12in sub. Power lite is on all cables are in correctly settings haven't changed cause it worked before. I'm not getting no more bass I'm getting sound out of the other speakers just not the sub? Is there anything I can do to fix this ? Thanx
Pogre
Pogre
Is this the one?
Did you check all of your connections? Sometimes a worn cable will give you problems or they wiggle loose, especially a sub. One of the leads to the speaker from the amp may have vibrated loose. If you're even a little inclined that's a pretty easy fix. Also, did you contact the manufacturer?
Bucknekked
Bucknekked
what are you using for a signal source to the subwoofer? An AVR?
If you have gremlins in your home (I have 21 grand kids) its possible an AVR setting in bass mgt got changed. Running your setup for speakers is a quick way to define if the system thinks your sub is OK.
You should have an option to run sound to L R, and SW during setup. If it doesn't work there, then I'm with Pogre: check cables or the sub itself. If setup drives sound to the SW, but normal play doesn't, it could be an LFE + sub setting that's out of kilter.
Pogre has killer subs and if anybody knows how to get 'em to work, it would be him.
Mr. Bojankns
Im using a Denon avr and it's a lil old but works great. Well the settings option is ruled out cause it's just me my girlfriend, I guess a cable could be but I did chk the cables unplug plug em back in I haven't replaced them yet which was my next step
