mulester7why would we not want the very best sound quality possible for either application?.....comments said:
...I'm too lazy to read through the entire thread, so if some of this has already been said, my apologies...
IMO HT isn't nearly as demanding from an "audiophile" POV...You need loud...you need directional cues...you need LFE...accuracy is not paramount.
If you take a look at some "state-of-the-art", pro-installed, HT rooms many of them seem to use "pro" type loudspeakers...and by that I mean studio monitors, more suited to post-production work than to audiophile-type concerns.
Let me clarify a bit...not that they are inaccurate or completely unsuitable(they aren't) but, many of these products are simply not used in accordance with the manufacturers intent. If you take a product that is designed to be a near-field radiator with quite specific placement guidelines(in order to present a proper image and exhibit a smooth FR) and place them contrary to those suggestions, something has to suffer. Yes, they might be able to handle a great deal of power and yes, they may be able to present an enjoyable soundfield but...watching a movie and HT in general, isn't quite the same as listening to a strictly audio presentation. In addition to that, the sound is processed(LFE, surround, etc.) to enhance the visuals and in some respects, take up the slack; it's a package deal...with audio you get audio, no distractions.
Laser-totin', mechanical lizards don't quite require the subtleties of a string quartet. IMO two dedicated systems is probably required for optimum enjoyment of both mediums. Failing at that, I would opt for the best reproduction for audio. While it may not be optimized to shake the rafters(although in some cases it might), if it presents a good, stable image with a wide and smooth bandwidth, it should be more than sufficient to provide a reasonably satisfactory HT experience...after all it's only tee-vee.
jimHJJ(...TTFN...)
