Home Made Corner Bass Trap Design with Pictures
Thanks! The bass is definitely less boomy, and overall sound has improved. Need to calibrate the system again.
Can you show before and after measurements for your various changes?
You can combine measurement with some eq by using a measurement mic (like a miniDSP UMIK or a Dayton USB mic or a few others) along with software like REW....which can also help determine and implement eq. What's the rest of your gear you have to work with? Probably something from miniDSP for implementing the eq would work.
DtotheC
DtotheC
Thanks! Ill check out those mics. Im running the following
Onkyo TX-NR5100
FRONT = Klipsch Icon KF-26
CENTER = Definitive Pro Center 1000
REAR and ATMOS = Origin Acoustics (probably a base model from builder
