I don't know....
According to Stereophile, most amps have a WIDE-BAND Unweighted SNR of less than 80dB!
$99,000/pair Boulder monoblock - "The 2150 was
extremely quiet—its unweighted, wideband signal/noise ratio with the input shorted to ground measured
78.5dB ref. 2.83V into 8 ohms."
Read more at
https://www.stereophile.com/content/boulder-amplifiers-2150-monoblock-power-amplifier-measurements#wOqHqK6YqRuPTi3V.99
$55,000/pair Dan D'Agostino monoblock - "The unweighted, wideband signal/noise ratio, ref. 2.83V into 8 ohms and taken with the input shorted, was a good
77.2dB."
https://www.stereophile.com/content/dan-dagostino-momentum-monoblock-power-amplifier-measurements
$30,000/pair Mark Levinson - "With the input shorted to ground, the Mark Levinson No.536 amplifier offered a wideband, unweighted signal/noise ratio of
71dB, ref. 1W into 8 ohms."
Read more at
https://www.stereophile.com/content/mark-levinson-no536-monoblock-power-amplifier-measurements#k756T9cJJ6iexOcq.99
$30,000/pair AVM Ovation monoblock - "The wideband signal/noise ratio ref. 1W into 8 ohms, taken with the input shorted to ground, was okay, at
74.6dB".
Read more at
https://www.stereophile.com/content/avm-ovation-ma82-monoblock-power-amplifier-measurements#SS1YtmDzy1iRCiiQ.99
$22,500/pair Krell 575 monoblock - "Measured with the balanced input shorted to ground, the unweighted, wideband signal/noise ratio was very good, at
78.2dB ref. 2.83V into 8 ohms."
Read more at
https://www.stereophile.com/content/krell-solo-575-monoblock-power-amplifier-measurements#MvyPo05ozJ3q5SkR.99
$12,000/pair Theta Digital Prometheus monoblock - "the unweighted, wideband signal/noise ratio, ref. 2.83V into 8 ohms, was
76.3dB"
Read more at
https://www.stereophile.com/content/theta-digital-prometheus-monoblock-power-amplifier-measurements#YvA30QF7EtsI8W1u.99
$12,000/pair Bryston monoblock - "The 7B SST2 is a quiet amplifier. Its unweighted signal/noise ratio (ref. 1W into 8 ohms) measured
75.6dB"
Read more at
https://www.stereophile.com/content/bryston-7b-sstsup2sup-monoblock-power-amplifier-measurements#W2ckQg26tWeiXDml.99
$11,000/pair Pass Labs XA60.5 monoblock - "The unweighted, wideband signal/noise ratio, ref. 1W into 8 ohms and taken with the input shorted to ground, was a good
79dB."
Read more at
https://www.stereophile.com/content/pass-labs-xa605-monoblock-power-amplifier-measurements#3GzBW1uS0hLJdEfZ.99
$50,000 Mark Levinson monoblock - "The No.53's unweighted, wideband signal/noise ratio, ref. 1W into 8 ohms with the input shorted, was therefore still lower than usual, at just
52.1dB."
Read more at
https://www.stereophile.com/content/mark-levinson-no53-reference-monoblock-power-amplifier-measurements#7c2wKuYjVc5ogkov.99
So maybe we should lower that number down to
52dB?
