Help with Dual Subs
K
Kaiser Roll
Hello, I'm currently using a Yamaha RX-A880 receiver in a 7.2 set-up L/R, C, Surr.,Front Presence and two Definitive Tech Powered Subs connected to the receivers Sub 1 and Sub 2 LFE output. My question is I'm not sure if the Sub 2 is active when watching a movie in Surround. Or is the Sub 2 output only active when using a Zone 2 with separate speakers in that zone. When I run a test tone only one Sub shows on the graphic.
Thanks
shadyJ
Speaker of the House
Both sub outs are running as a single signal that is split into two outs. Sub 2 output should be active on any mode where subs are active.
Are you not hearing anything coming out of sub 2? (actually sometimes it's easier to just lightly touch the cone). Like shady says.....
Then again to not be able to recognize a sub is actually on isn't necessarily a bad thing.....is sub 1's location and volume easily discerned?
K
Kaiser Roll
I definitely can tell that Sub 1 is active but I'm not always certain about Sub 2. I'll have to get down to eat level and feel the cone for activation.
Pogre
Pogre
Just lightly touch the edge of the surround and feel for vibration.
I actually do that all the time. I love my subs...
shadyJ
Audioholics isn't your own personal erotica website! ;)
Ideally you don't want to be able to localize your subs. How did you choose the sub locations to start? Setup details with what gear (did you use YPAO)? What crossover are you using?
Trebdp83
Love em' or not, keep touchin' your "subs" and you're gonna go blind. ;)
Pogre
Pogre
I'm working on a sub erotica fan fiction post right now. I might include @Danzilla31 as the sub-port antagonist for an interesting love triangle story.
Trebdp83
Well, go ahead, lean that chair back and...;)
Trebdp83
I hope the OP doesn't come back around. I can just hear them now, "What in the f$%k!":D
K
Kaiser Roll
Both Definitive Technology Subs sit to the left and right of the Mounted TV due to space restraint. I currently have Elac Debut 2.0 f6.2 main speaker with Elac front presence and surround speakers. Polk signature series center speaker because of the low profile. I did use YAPO but those measurements like the test tone only show one subwoofer. Subs sit between the mains and TV.
Pogre
Pogre
Have you determined whether or not sub 2 is working??
